Author Topic: Starter cable replacement  (Read 1276 times)
baron_matt
« on: September 18, 2014, 12:18:45 PM »
Well lol one of the few remaining components that haven't been replaced failed on Monday. The Starter cable has busted.
I have a new cable and set of clips on their way to me, but a look through the haynes gives no clue on how to replace this.
Since I have a one piece carpet in, i'm guessing that first step is to remove seats and seat belt mounts so that I can get the carpet up and get access to the tunnel.
I've seen an earlier post on this forum about there being a cable clip on the metal heater pipe, so is the way to fit this cable by threading it in from the back end?
I saw rusty's post about a cable being too long. What length should the cable be before I start taking the car to bits?
baron_matt
Re: Starter cable replacement
« Reply #1 on: September 23, 2014, 11:59:28 AM »
Well starter cable is now replaced along with all clips and it works as it should, however a kinked choke cable was spotted so that will be the next item needing changing.
Cable routing seems really critical so I think the choke cable has been routed wrongly on the car which is causing the kinking.
I cannot find anything listed in the haynes re the cable runs so does anyone have any advice?
