Author Topic: clutch problems  (Read 1269 times)
tappy
clutch problems
« on: September 05, 2014, 06:53:55 PM »
I've replaced the clutch assembly  on my wifes 126 bis  , replaced the cable (with some help from your forum)
but now i cant get it adjusted
ive turned the setsrews up and down the tread for several times and seems rarely can find the sweet spot where the pedal engages the clutch
when i find that spot it feels like the cable comes to a point of alot resistance and then "knacks" and engages like it should but up on releasing the pedal the clutch does'nt engage anymore or ekeeps engaged
now i'm wondering could i installed the friction plate wrong ? or is there something wrong with my way of adjusting the mechanism
does anyone knows a site for "fiat 126bis clutch adjusting for dummies " becouse i cant get i figured out yet
tappy
Re: clutch problems
« Reply #1 on: September 05, 2014, 07:37:04 PM »
after fiddeling some more i found the sweet spot , meaning when i dont press the pedal and the car is running it grinds when i trie to put it first gear , if i press the pedal it doens grind
so far so good
but now up and runing int first gear the car aint moving  :(
is there aniting else i need to adjust ?
