Author Topic: Knacking from front wheel with every rotation of the wheel... felt through pedal  (Read 1535 times)
poxxxy
So...
Had this little issue for a while but only noticed it usually when braking and cornering slightly... After having the car up to underseal it with Tetra Schutz and having all the wheels and drums off... The problem seems to have gotten worse and is just knacking with every rotation of the wheel :(. Not exactly sure whats causing the problem, had the drums off to inspect them all today and everything looked ok? Could it be the locating pin being too long and catching on the shoes or something?
Looks like i'll have the task of getting it up again tomorrow!
124cso
Have you checked the bearings ? (I assume you mean on the front wheel ? ) Just that I'm thinking it must be fairly substantiol thump to come up thru the pedal/s.
« Last Edit: September 05, 2014, 03:47:16 AM by 124cso »
poxxxy
Bearings all seem fine, kingpins been replaced etc... Gotta be something catching somewhere but can't see any evidence of it!
poxxxy
So it was the locating pins bought from 126fan, seems they are too long and catching on something somewhere!
