Author Topic: Steering wheels, whats your look like?  (Read 11455 times)
Bruce
« Reply #15 on: May 16, 2006, 01:07:52 AM »
i think it depends on which 500 and which 126 you have. mine was for a bis it may also fit later aircooleds. i think italian built 126 shared the boss with the 127 and possibly the last 500s. If you get hold of a 500 wheel/boss and it don't fit it will be easy to sell it on on ebay.  If you just get a wheel it may be possible to adapt a standard wheel to act as a boss; doing that also means you can use the standard horn push, thats what i did with my first 126.
paul harbinson.
« Reply #16 on: May 16, 2006, 07:38:38 AM »
I have a wheel for a 500L but the slalks(cinquecento) would need modified,as in do away with the self cancelling mechanism.
Dante Giacoso, pure genius!
VESPA210CM3
« Reply #17 on: May 16, 2006, 08:36:58 AM »
Quote from: "Bruce"
i think it depends on which 500 and which 126 you have. ....
I've got a 1989 - 126 Bis ...
 :arrow: If some of you, saw on eBay a sporty steering wheel and boss than can fit a 126 bis let me know ...  :wink:
is for FIAT 126 BIS ... VESPA & LAMBRETTA !
VESPA210CM3
« Reply #18 on: March 10, 2007, 09:58:47 PM »
:cry: who can tell me if you see a FIAT 126 BIS boss + steering wheel (like a Mountney) on eBay ??
Bruce
« Reply #19 on: March 12, 2007, 05:53:04 PM »
there is a french company called Ector that do a universal boss that will take a wheel from most of the popular wheels such as mountnoy and Momo, you would probably be in a better position than most to contact them and see if they do one that will fit yout Bis. also Mountnoy definatly used to do a boss because i have one, also Momo may do one. Once you have your boss any wheel will do. You could even make a boss out of your standard wheel.
VESPA210CM3
« Reply #20 on: March 19, 2007, 10:07:21 PM »
:cry: well Ektor dont have a 126 BIS hub boss ... if you see one for a Mountney on Ebay send me a MP  :wink:
« Reply #21 on: March 19, 2007, 10:15:05 PM »
the boss and steering wheel that i have was advertised as for early 126,but they went straight on my fsm 650,only the hooter button electrics/ center cap did not fit...i used the mountney center cap and rewired the horn to another swtich...
Bruce
« Reply #22 on: March 21, 2007, 07:33:36 PM »
there's an arbath steering wheel on ebay, it has what looks like a MOMO size centre so you will be able to modify your original wheel to take it if you cant get hold of a hub/boss.
