Hi All
As I have removed the carb I thought I`ll have ago refitting the broken/missing choke
activator
first remove the butterfly valves, then the shaft and if its still there the small brass end disc
remove the diaphragm/plunger on the side of the carb
make sure the choke activator is the correct way around "same as picture"
Then its a matter of sliding the activator up and pushing the butterfly valve shaft though
I have cleaned and repaired the diaphragm "seems it just a push fit with a few punch marks holding
it at together
All done and screwed back on the carb "still not sure what it does
Pete
