Author Topic: Car wont start..  (Read 7002 times)
Bar Vitelli
Re: Car wont start..
« Reply #15 on: August 04, 2014, 06:50:34 AM »
I think Rusty's idea about putting a small amount of fuel directly into the carb might work, could be a fuel pump thing...
Every cloud has one...
DeVilleChris
    • Club 126 UK
« Reply #16 on: August 05, 2014, 01:14:04 PM »
Rusty you nailed it. A bit of fuel down into carb and it fired for a few sec, then I put the plastic elbow back on too of carb and it doesn't. Any ideas?
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
« Reply #17 on: August 05, 2014, 03:36:29 PM »
Great now you know that it is fuel related so you can forget about the ignition. If the engine has not run for a long time you could repeat the "treatment" a few times to see if anything frees off or clears but be careful with the petrol. If you get no joy check the fuel supply. Disconnect pipe at carb & stick it in a jam jar , turn over engine to see if fuel is pumping. If that is ok and still no go then a strip down and carb clean would be next move  :)
DeVilleChris
    • Club 126 UK
« Reply #18 on: August 05, 2014, 03:50:33 PM »
Thanks rusty. I have checked the fuel supply.. It's all working, so it's going to have to be carb strip can clean. Any tips for it?
DeVilleChris
    • Club 126 UK
« Reply #19 on: August 05, 2014, 04:10:09 PM »
Also the carb mixture screw is strange, there is no spring on it, its just a screw into the hole, its not like that on my other cars, is that usual?
baron_matt
« Reply #20 on: August 05, 2014, 04:51:53 PM »
I think there should be a rubber O ring on it, this can fall apart.  Sounds like you need to get that carb off for a proper strip down. I found that the well in which the gauze filter sits can corrode up. It might be that you need to get yourself a bucket of Vinegar and give the carb a good soaking. :-)
DeVilleChris
    • Club 126 UK
« Reply #21 on: August 05, 2014, 05:01:45 PM »
I will take a carb off one of the spare engines for now, and have a go at stripping the one thats on now.
DeVilleChris
    • Club 126 UK
« Reply #22 on: August 10, 2014, 07:17:54 PM »
Cleaned carb in Vinegar.. it looks very nice. Exactly the same issue though
Mics126
« Reply #23 on: August 10, 2014, 07:40:33 PM »
Does the float and needle move freely up and down.
DeVilleChris
    • Club 126 UK
« Reply #24 on: August 10, 2014, 07:43:26 PM »
Yeah they look to be fine
DeVilleChris
    • Club 126 UK
« Reply #25 on: August 23, 2014, 05:23:17 PM »
Success!!
After lots of tinkering and messing around, lots of carb cleaner and scrubbing, the car is running!  ;D
Mics126
« Reply #26 on: August 23, 2014, 08:20:09 PM »
well done and hopefully it says that way :wave
I think you deserve one of these :beer:.
Mike.
« Reply #27 on: August 23, 2014, 10:13:56 PM »
Well done Chris :thumbup
DeVilleChris
    • Club 126 UK
« Reply #28 on: August 24, 2014, 07:29:07 PM »
So, today I repaired the choke cable and starter motor cable by replacing them, and it ran fine before this, the timing was a little out but it ran...
Then got in the car and attempted to start it, after it turned over a couple of times there was a huge pop.. Now it just turns over but won't start.. I still have sparks at the plugs and fuel going through the carb...
1 step forward 5 steps back
Mics126
« Reply #29 on: August 24, 2014, 08:15:25 PM »
like you said its probably just the timing. thats proberly what the pop was just unburnt fuel.
hopefully you fix it again, i probably spoke to soon. :(
Mike
