Author Topic: Disc brake conversion adaptor plates  (Read 7656 times)
Re: Disc brake conversion adaptor plates
« Reply #15 on: August 25, 2014, 08:51:55 PM »
You can buy adapter plates for the back, they come up on eBay from time to time. I bought mine from Poland which use FSO or x19 callipers.
dom.kellett
« Reply #16 on: August 25, 2014, 09:08:28 PM »
Ok then, thankyou :) I have a few options on how to make my BiS nippy so need the stopping power aha thankyou
Mics126
« Reply #17 on: August 25, 2014, 10:25:45 PM »
i know i will probably get alot of people arguing with me but technicaly the drums are better brakes when it comes to pure braking force (mine will stop from 50mph on the dot),the only issue is as always just the cooling. i'm planning to make a water cooling system for mine because i'm planning to add a few horses myself.
Mike
« Reply #18 on: August 26, 2014, 09:08:22 AM »
I had drums all round on mine and then fitted the disc brake conversion on the front. I bought the adaptors from a polish company called TRS and the discs and calipers are from a punto mk2 (mine actually uses OMP cross drilled discs and pads) the whole kit cost around £130 using good second hand calipers (god only knows how some company's charge over £600!!).
Personally it's the best upgrade I've ever done and well worth the money and I'ld recommend them to anyone. The stopping power is sooo much better and there's no worries about them being too good and locking up at the first press of the pedal.
« Reply #19 on: August 26, 2014, 12:48:43 PM »
It was TRS I bought the rear adaptor plates from.
« Reply #20 on: August 26, 2014, 07:49:02 PM »
Interesting debate going on here but don't think that I can agree with Mike about drums being better otherwise modern cars would use them and F1 racing cars would be fitted with carbon fibre brake drums  :o
A well set up & maintained standard system will work well and under normal conditions are adequate but with a 126 you are relying on a slightly "pepped" up system that was designed in the 1950's and can be subject to brake fade when they get hot or find you standing on the pedal & hoping when trying to slow quickly from "high"speeds. Like Gadge says with a non-servo system using the original master cylinder you get a nice balance to the brakes without them being too harsh and no chance of brakes overheating or fading under load.
« Reply #21 on: August 26, 2014, 08:21:26 PM »
Drums will never be a better braking system over discs. The only reason that moderns use them on the back is that they are sufficient at bringing the rear under control. Discs are a far superior design as there's more surface area to grip plus they cool down better and wear evenly and won't stick as there are no adjusters. There deffinatly the way to go on our cars - not wholly nessarcey on the rears but no reason why you can't upgrade them to make the system technically better :)
« Reply #22 on: August 26, 2014, 08:25:50 PM »
I've got all the bits to do rears on mine I'll do a full write up soon!
« Reply #23 on: August 26, 2014, 08:32:06 PM »
Nice one stuey :D its the handbrake cable that confuses me lol
poxxxy
« Reply #24 on: August 26, 2014, 09:15:12 PM »
Hmmm... how many sets you got Rusty? I might be tempted as soon as I get her through MOT as I've got a nasty noise coming from the passenger front drum/shoes... and not sure its just me or somethings not quite right but it does take a while to stop and needs much planning in advance!
Mics126
« Reply #25 on: August 27, 2014, 08:25:41 PM »
has anyone on here herd of self-servo action. if you keep your drums cool then they are more efficient at stoping. the reason f1 and other motorsports are using them i the reason that someone else aready said and i agree about that is pure cooling effect. but on the road if you keep them cool then they are more than enough for a 126.
i'm not going to argue with any one because i'm not after that i'm just trying to inform people.
Mike
« Reply #26 on: August 27, 2014, 09:19:32 PM »
On some old motorcycles they had a  scoop to direct additional air to cool the drums. Generally on the front of tritons etc
Mics126
« Reply #27 on: August 28, 2014, 08:50:13 PM »
I was going to use water cooling for my drums. they do it to disk brakes by cooling down the calipers with water in rally cars.
Mike
