Author Topic: Scuby 1800cc install  (Read 25552 times)
Dom.kelltt
Re: Scuby 1800cc install
« Reply #45 on: April 19, 2015, 12:08:01 PM »
It's looking great! Love your engineering skills and how neat and tidy all the work you do it! Are you going to adapt the original gearbox to put the power down or at least help it live a little longer?
« Reply #46 on: April 19, 2015, 03:04:08 PM »
I will inspect All gearbox internals to ensure they are in good condition, replace if required and hope for the best.
Dom.kelltt
« Reply #47 on: April 19, 2015, 11:12:09 PM »
Ahh right ok then,
Brilliant work though! Can't wait until this project is done so I can see if it's worth me trying my hand at the fabrication you have done :)
Great thread and keep it up!
thanks Dom
« Reply #48 on: April 26, 2015, 06:56:32 PM »
I had a major problem in finding someone who could supply an ignition coil to the correct primary and secondary resistance specified in the manual. Took a punt and emailed acuspark and the tested some coils and one fell into the mid range specified in the manual and it only cost £12, should arrive Wednesday. So hopefully I will fire it up next weekend.
Dom.kelltt
« Reply #49 on: April 26, 2015, 08:57:54 PM »
Great news! I've been offered a 2.0ltre turbo for 100 (with a few minor issues) and then I'm planning on using a 944 box in order to reduce the amount of gearboxes I shall tear through
« Reply #50 on: April 27, 2015, 12:43:19 PM »
944 box sounds interesting, I assume it's standard adapter plate as used on the beetle Subaru conversions.
Dom.kelltt
« Reply #51 on: April 27, 2015, 03:44:41 PM »
Yup, that's exactly what I'm thinking, just sort or copy what they do but incorporate the attempt to shorten everything (126's are tiny compared) lol
Also, I know I've asked you loads of questions but I have one more if that's ok,
How are you planning on mounting it into the car? But the same method as original engine or by making an adapter plate to lock it to the car??
Thanks Dom
« Reply #52 on: May 02, 2015, 06:16:59 PM »
Dom, I intend to adopt the same support system Alistair used on his conversion. I will see if I can post a link. I finally managed to fire her up, she lives. Only problem one cylinder has only50 while the others have 210 when I did the compression test. Anyway it all seems to next is the trial fit to finalise position of rediator and exhaust.
Dom.kelltt
« Reply #53 on: May 02, 2015, 06:31:45 PM »
Great news! Yeah if you could try upload some images that would be great! 😏 should be getting an engine tonight or tomorrow just need to go pick it up now that's all :) getting very excited lol
Glad to hear she lives and runs! Bet your chuffed with it right now! :)
« Reply #54 on: May 02, 2015, 06:49:07 PM »
The web site is www.retro500.com  go to engine swap gallery and then to Alistairs Subaru 1800.
Dom.kelltt
« Reply #55 on: May 03, 2015, 12:21:54 AM »
Perfect Thankyou :) should be picking up my block tomorrow :)
Dom.kelltt
« Reply #56 on: May 03, 2015, 12:27:19 AM »
Quite a good idea he has used there :) I'll definitely go for that one, looks strong, sterdy and reliable :) Thankyou for that like Ralph :) hope your conversion is complete and running soon!
« Reply #57 on: May 03, 2015, 10:09:07 AM »
I am finding it difficult to locate an engine gasket set, can get it from Australia or America but at a price, the ej engine might have been the best option as spares are abundant. I will continue with the trial fit and see how much work is required to fix the compression issue. I may have to change to an ej if the bore in mine is done.
Can't wait to see your progress photos.
Dom.kelltt
« Reply #58 on: May 03, 2015, 03:28:39 PM »
Ah sounds like a tricky situation then,
Hope you manage to source one soon!
Should be picking the engine up soon so fingers crossed lol
« Reply #59 on: May 09, 2015, 08:25:55 AM »
Latest update, tried everywhere to get a gasket set but to no avail, one of the engine machine shops said I would have to supply the block + oversize pistons and rings if I wanted a re-bore, another said he couldn't find anything listed for this engine. So I am now weighing up the cost of importing what I need to fix the engine against buying an ej20, so if you are thinking on a Subaru replacement engine I would not go for the ae81 or 82.
