Author Topic: Idle Mixture & idle setting up?  (Read 4533 times)
andyzeetec
  • 126 BIS
« on: June 12, 2014, 01:17:50 PM »
Hi all
Got a lumpy erratic tickover so had a play around with the mixture. Is there a recommended number  of turns out for this screw, 1½  or 2? as a std setting?
Is the idle mixture set for best running or to pass mot at not necessarily best engine running?
As I understand the way to adjust the idle mixture is to screw in slowly till nearly stalls, then back out slowly to find the highest tickover/revs, sweet point, keep unscrewing till runs lumpy again then screw in ¼ turn.
So I screw in until nearly stalling, screwed  out to find highest revs which came back to my lumpy tickover but the revs did not really increase to a peak, didn’t want to unscrew it too far or any further  in case screw came out.
Am I doing it correctly,which way is leaning it up, do I need to remove carb & clean jets, check float height, does adjusting the idle screw affect starting in combination with mixture screw as it seems harder to start now?(I did notice on carb that when you set full choke the throttle butterflie/s open a fraction and also if you open the throttle with full choke, the choke lever now drops, comes off slightly)
Like an idiot I forgot to screw mixture screw in and note the turn # before playing around with it. :$
Many Thanks
Da Londo
    • Fiat 126 blog
Re: Idle Mixture & idle setting up?
« Reply #1 on: June 12, 2014, 02:29:02 PM »
1½  is about right and I always used to fiddle after MOT. You runnning a BIS?
andyzeetec
  • 126 BIS
« Reply #2 on: June 12, 2014, 10:12:10 PM »
Yes
« Reply #3 on: June 12, 2014, 11:32:45 PM »
Hi all
The 1 1/2 to 2 is a starting point not a standard setting
There's no difference, if its set up properly the engine will run smooth and produce less Co2
That's how i was taught to setup the idle mixture in 1852 ;) Forget about the 1/4 - 1/2 turns it doesn't work that way
(keep unscrewing till runs lumpy again then screw in ¼ turn.
So I screw in until nearly stalling, screwed  out to find highest revs which came back to my lumpy tickover but the revs did not really increase to a peak, didn’t want to unscrew it too far or any further  in case screw came out)
Am I doing it correctly, YES
Which way is leaning it up,
The idle mixture screw is shaped like a cone, this fits into a pre-drilled hole, by screwing it in this leans the idle mixture (only) by filling the hole thus limiting the amount of petrol into the venturi
Do I need to remove carb & clean jets, check float height,
Not if the above sorts out the problem
Does adjusting the idle screw affect starting in combination with mixture screw as it seems harder to start now?
NO - its more likely to be points, plugs or ignition timing
That's Normal
Many Thanks
andyzeetec
  • 126 BIS
« Reply #4 on: June 17, 2014, 02:54:21 PM »
Thanks Pete.  :beer:
andyzeetec
  • 126 BIS
« Reply #5 on: July 07, 2014, 01:12:08 PM »
Got the carb off, jets were partially bunged up in the float bowl, so maybe that was the cause of the struggle starting/rough idle.
My question is the regarding the pic below of the idle screw (thin screw). The rubber seal had a few bits of shavings come off as I unscrewed it, so I want to renew it, but there are only o-rings in the carb kit. The seal on the screw looks like it is a different type. Can anyone help, as I dont want to cut it off and fit an O-ring if it's not suitable.
Thanks.
poxxxy
« Reply #6 on: October 03, 2014, 04:30:43 PM »
What did you do with the idle screw seal in the end?
andyzeetec
  • 126 BIS
« Reply #7 on: October 03, 2014, 06:08:59 PM »
It was an o ring but well and truely shot, Cut it off and put a new one on with a drop of oil to seal.
:)What did you do with the idle screw seal in the end?
