Hey John,
Have you tested the starter motor? Connect the starter motor across a battery as in the photo, If the motor spins the fault is in the solenoid mounted on top, These can be bought separately for about 23 euro, the only other thing to check is that the lever at the end of the solenoid is not seized and is throwing the starter gear into the ring gear on the flywheel
