Author Topic: Won't Start  (Read 2141 times)
essex southend
Won't Start
« on: March 23, 2014, 10:26:53 AM »
Morning All
Drove the car out the garage no problems,  pop in doors for 10 minutes, back to the car turn ignition and nothing  ??? all the lights come on and the battery is okay.... anyone point me in the right direction please?... I suspect the connector on the starter motor.
Re: Won't Start
« Reply #1 on: March 23, 2014, 11:11:12 AM »
I've had this happen to me twice - both times in a petrol station just after filling up. After the first time I put it down to a dodgy ignition switch so swapped it with another one I had but then it happened again so I came to the same concussion as you did and thought maybe it was the starter motor sticking. It hasn't done it for a while so it's never been a concern yet
essex southend
Re: Won't Start
« Reply #2 on: March 23, 2014, 12:02:17 PM »
Thanks Gadge,  will take a look when I get home from work
Ray
Bar Vitelli
Re: Won't Start
« Reply #3 on: March 23, 2014, 03:34:52 PM »
Why are you doing working on a Sunday, Ray? That day is supposed to be reserved for fixing Fiat 126!
Try cleaning the carb (and the contacts)...that usually fixes most things!
Every cloud has one...
essex southend
Re: Won't Start
« Reply #4 on: March 23, 2014, 03:44:33 PM »
Tell me about it I should be at home,  I think it is more electrical but hey ho a day off tomorrow so it is going to be a car day.  :)
essex southend
Re: Won't Start
« Reply #5 on: March 24, 2014, 05:53:41 PM »
Problem was the starter motor connector which I have now replaced,  have also fitted the new number plates, fog lights and made a hinge for the drivers door so well chuffed.
kev126
  • Built not bought
Re: Won't Start
« Reply #6 on: March 27, 2014, 12:49:18 PM »
A known culprit! It's always a good idea to take time of a day off to clean (replace if needed) as many connections as you can get your hands on.
1989 Fiat 126 BIS
