Author Topic: Gearbox Oil  (Read 2185 times)
essex southend
Gearbox Oil
« on: March 14, 2014, 06:35:26 PM »
Thinking I could be dim but I want to top the gearbox oil up but I can't find where the plug is located,  can any one help or post a picture for me.
Thanks again
Re: Gearbox Oil
« Reply #1 on: March 14, 2014, 07:41:17 PM »
It's on the side by the starter motor. Looks like a square 1/2 inch plug.
Scarlettkitten
Re: Gearbox Oil
« Reply #2 on: March 14, 2014, 07:41:48 PM »
If it's a BIS its on the drivers side of the gearbox, 13mm square ended plug.  I've just topped mine up :)
beat me too it /\ :)
1990 126 BIS
essex southend
Re: Gearbox Oil
« Reply #3 on: March 14, 2014, 07:46:23 PM »
Thanks,  I think that it has been located,  it has an oversize bolt in it, will try and post a picture.
essex southend
Re: Gearbox Oil
« Reply #4 on: March 14, 2014, 10:27:10 PM »
Is this where the gearbox oil filling should be?
andyzeetec
  • 126 BIS
Re: Gearbox Oil
« Reply #5 on: March 14, 2014, 10:51:04 PM »
This is it on the bis, not sure if aircooled is the same...I found this pic some time ago.
good luck with undoing it, had a go at mine today and cant budge it, had a search tonight on the forum and found this method which I have yet to try, but sounds good...
"use a short 1/2" drive socket extension , reverse it & tap it onto the square plug head then it is easy to get a spanner on the square end of the extension and makes it much easier to get a good hold on the plug"
« Last Edit: March 14, 2014, 10:55:54 PM by andyzeetec »
126blackbird
Re: Gearbox Oil
« Reply #6 on: March 15, 2014, 09:53:07 AM »
Make sure you use the right oil.........................don't use EP oil
essex southend
Re: Gearbox Oil
« Reply #7 on: March 15, 2014, 10:00:54 AM »
Thanks Blackbird...looking at my photo is this where I should top up?  thanks
Bambino126
Re: Gearbox Oil
« Reply #8 on: March 16, 2014, 07:14:27 PM »
Try this:
Take a 12 mm half-inch drive long nose socket, preferable a hexagonal one as opposed to the bi-hex design.
Hammer the square end on to the filler plug. Then insert a large 12 mm Allen key in the hexagon end and turn.
If you don't have such a big Allen key then a hex bit socket and driver will do.
You can use any matching socket and Allen key e.g 10mm socket and 10mm Allen key, I just chose 12mm because it gave a big enough Allen key to put enough torque on to undo the plug.
rick
Re: Gearbox Oil
« Reply #9 on: March 23, 2014, 03:56:55 PM »
What oil should be used?
