Author Topic: Alternator drive belt (9.5mm or 10mm wide)  (Read 1837 times)
andyzeetec
  • 126 BIS
« on: February 22, 2014, 10:02:38 PM »
Received a belt amongst other stuff from axel, but it is 10 x 725 and protrudes a bit too much from the pulley for my liking. It should be 9.5mm I think?
Do you reckon it will be ok, or should I change it?
Re: Alternator drive belt (9.5mm or 10mm wide)
« Reply #1 on: February 23, 2014, 11:18:07 AM »
That's not a problem Andy, once you put the new belt on drive the car for 1/2 hour let the engine cool and re-check the tension :)
andyzeetec
  • 126 BIS
« Reply #2 on: February 23, 2014, 12:25:15 PM »
Ok thanks Pete, also noticed the alternator rotates very freely, is that normal or should there be some resistance?
« Reply #3 on: February 23, 2014, 12:53:09 PM »
That's normal, You only get resistance when there is a load on it ;)
andyzeetec
  • 126 BIS
« Reply #4 on: February 23, 2014, 01:57:11 PM »
ok, thanks
