Author Topic: High rev-rev-reving  (Read 1289 times)
scotty
    • iamscotty
High rev-rev-reving
« on: February 05, 2014, 06:51:33 PM »
I've noticed something creeping up a bit recently and getting very noticeable now.
Once the engine's got up to temp I have noticed that the rev's are not dropping back down very quickly when I drop off the gas.
At first I thought my throttle cable might be stiff but it's fine at low temperatures.
When in traffic and I press in the clutch it races up a fair bit before gradually drops down to a slightly fast
idle.
I'm wondering if this is a bit of a timing issue but not sure where to start checking.
Hmmm?
grubscrew
Re: High rev-rev-reving
« Reply #1 on: February 09, 2014, 04:24:09 PM »
Try at the engine end once warm, then that will eliminate whether it is the cable or otherwise.
All things Italian.
Mics126
« Reply #2 on: February 09, 2014, 08:43:53 PM »
it sounds like the mixture is abit rich. first try to screw in the idle mixture screw.
hopefully that works.
