Author Topic: Carello Head lamps  (Read 1358 times)
essex southend
Carello Head lamps
« on: February 04, 2014, 06:42:39 PM »
Can any one tell me what bulbs fit the above as the ones I took out are too small.
Re: Carello Head lamps
« Reply #1 on: February 04, 2014, 07:37:40 PM »
essex southend
« Reply #2 on: February 04, 2014, 07:55:49 PM »
Thanks for that,  I did buy some from a local shop but they were the same size as the ones I took out of my LHD lights so if the ones you got are bigger then I will order them.  Thanks
« Reply #3 on: February 04, 2014, 08:18:30 PM »
The ones in the shop are the correct wattage 40/45 Halogen Bulbs so there's less chance of burning out the headlight switch which is a common problem if you put the higher power 55/60w bulbs in.
essex southend
« Reply #4 on: February 04, 2014, 08:33:59 PM »
Thanks for that,  wonder why the Carello lights diameter is bigger.
