Author Topic: Gearbox oil leak and suspect gearbox mounts?  (Read 2694 times)
andyzeetec
  • 126 BIS
« on: January 17, 2014, 12:37:49 PM »
I am guessing the oil leaks are due to the Drive shaft inner boots, I have had a shop round and it appears there are two types available, one with metal bushing and one with rubber bushing, does anyone know which ones I should buy. Anyone know whats involved in doing this job, is there a how to?
Also I have noticed the transmission mounts rubbers are perished, should I replace these or should they be ok. Is it a straight forward job?
Thanks guys.
adult photo sharing
how to take a screenshot on a pc
photo sharing sites
pictures upload
Captain Tracteur
  • Le cowboy from Hell! :)
Re: Gearbox oil leak and suspect gearbox mounts?
« Reply #1 on: January 19, 2014, 09:44:29 PM »
If the rubber boot itself is not ripped or broken, you might get away with replacing an oil seal. There's an oil seal ring (similar to a crankshaft oil seal) in a metal housing inside the rubber boot. You can gently pop it out and knock in a new one.
Its OEM number is: 40001720, and Corteco has it in its range on 12011443B
Replacing the rubber boot is pretty straightforward by the way.
Classic, not plastic :)
andyzeetec
  • 126 BIS
« Reply #2 on: January 22, 2014, 01:03:17 PM »
ok, thanks mate.
