Author Topic: air-cooled air filter tip?  (Read 3585 times)
markymarc
« on: August 06, 2013, 08:34:30 AM »
I picked up a windscreen from a polish guy last night & he told me how to tweak the lil air-cooled engine. He said cut off the original air filter tinware & fit a sports air filter onto the carb? Has anyone done this? Got any pictures or tips?
Marc
Seabee1978126
Re: air-cooled air filter tip?
« Reply #1 on: August 06, 2013, 08:54:20 AM »
I actually did this (sort of). I used the stock air filter and shoved it onto the plastic elbow that bolts onto the top of the carb.. It works and I "think" I may have felt a difference. As for the tinware.. I just put the cap back on so that it is still funneling the air to the filter. Now its a free cold air intake... kinda! :P
markymarc
« Reply #2 on: August 06, 2013, 10:32:30 AM »
Sounds similar, anyone else done it?
« Reply #3 on: August 06, 2013, 01:08:49 PM »
There is about 1/2 kg of steel bits inside on the fan side of the tinware for the air filter that can also be cut off.
I opted for The Delorto FZD carb so got rid of all that tinware and weight and welded-up the hole.
markymarc
« Reply #4 on: August 06, 2013, 04:31:36 PM »
Have you done other work on the engine though darrell?
Marc
« Reply #5 on: August 06, 2013, 09:24:32 PM »
Hot cam and carb change so far. A bigger sump and alloy rocker.
I went the route of bigger sump to help cooling and the high volume rocker gives more space internally.
The theory was to ease internal breathing of the engine.
I've binned the mechanical fuel pump and plated the hole.
Plans have always been for more stuff but finances failed me.
Finally decided what my 500 is going to be (more or less standard) which leaves the 126 to be played with more :)
I want to go bigger pistons, steel crank, and much modified head with twin downdraft webber but we'll see :)
« Reply #6 on: August 06, 2013, 11:30:04 PM »
Marc I have a panda 30 head and carb fitted with the old tinware removed see photo.
popik81
« Reply #7 on: August 15, 2013, 11:20:08 PM »
cold air is better?? I have 10 big holes drilled in bottom of that tin, and engine getting cold air from engine fan :)
markymarc
« Reply #8 on: August 16, 2013, 09:53:50 AM »
Can the engine lid be propped open for extra air on the 126 like the 500?
Marc
Da Londo
    • Fiat 126 blog
« Reply #9 on: August 16, 2013, 10:52:57 AM »
I'm going with an FZD too but I was thinking of getting cold air from the airbox above the engine, I think the engine bay heats
up too much so you will be sucking in hot air.
Seabee1978126
« Reply #10 on: August 16, 2013, 11:48:54 AM »
« Reply #11 on: August 20, 2013, 02:42:48 PM »
I've seen a few moded 500's now draw air into the engine from a duct out the side of the car rather than the standard set-up.
Thing is we think we are drawing in cool air but it is cool? Considering the tinwork the air is being drawn past is right next door to the engine which heats it all up.
Would we not be better-off using the vents that are standard to let some of the hot air out?
PS not used one of those filters, my FZD came with an old school trumpet and gauze :$
