Author Topic: 13 in wheels, need help with tires/tyres  (Read 5637 times)
Seabee1978126
Re: 13 in wheels, need help with tires/tyres
« Reply #15 on: August 27, 2013, 06:33:32 AM »
Ah very nice, thanks for the pic too. Is there different sizes for spacers? If so, which do you use?
Chewy
« Reply #16 on: August 27, 2013, 11:57:18 AM »
That would depend on the offset of your wheels. I use a 10mm spacer on 5.5 wheels with a pretty massive et 42.5 . So if you had an et 32.5, I guess you wouldn't need a spacer.
Also that's just on the rear wheels. I run discs on the front so it's not comparable.
Seabee1978126
« Reply #17 on: August 28, 2013, 08:35:22 AM »
Gotcha Chewy. I was debating throwing disk brakes on the front, but, I dont really see a point in it. I get that you brake stronger and faster. I just dont see the reason for the mod if I can barely get over 60mph.. The shoes last forever!! Unless of course you running a stronger engine and you need to be race ready at all times!!! :P
