Author Topic: Reverse eye leaf spring for BIS  (Read 4979 times)
fiat126fzr
Re: Reverse eye leaf spring for BIS
« Reply #15 on: July 25, 2013, 08:04:12 PM »
I'm in the process of trying to lower and stiffen up the suspension (and eliminate lift off oversteer above 90!) on my Bis so am at a similar stage to you. I've read up loads and from what I have found I am going for a 5 leaf reverse eye front leaf with rear shocks fitted to the front, then new rear shocks with 17cm springs. I'll be fitting 13x5.5 wheels at the same time (as well as disc conversion!) so if it isn't sat low enough I'm planning to cut the front mounting blocks. I'll let you know how I get on!
« Reply #16 on: July 25, 2013, 10:55:55 PM »
I fitted the reverse eye spring on my Bis but to be honest i think i would have been better taking the original spring to a specialist re-manufacturer who can flatten the spring to reduce the ride height as 126 owners do in Poland,
I bought the spring from 500 mania and although it may fit the 500/126 aircooled it produces allot of positive camber on the Bis and does not lower the car to what i wanted, The only way i can get the front end down is by putting some weight in the front boot, there are mods you could do to sort out the positive camber and that's to weld the hole in the top suspension arm and then re-drilling the holes further in on the arm to create negative camber ;D
« Reply #17 on: July 26, 2013, 10:21:23 AM »
as pete top arms can be easily modded to effect the camber- i also lost a leaf from mine to get it lower...
fiat126fzr
« Reply #18 on: July 30, 2013, 07:41:26 PM »
Just dropped my leaf off to an engineering firm in Portsmouth today. I'll let you all know how I get on with them and their work in due course.
« Reply #19 on: August 01, 2013, 08:41:15 PM »
I posted this link a whiie ago, I think this is how Steve (Smallcox) lowered his 126 Turbo
http://www.jalopyjournal.com/forum/showthread.php?t=90824
kev126
  • Built not bought
« Reply #20 on: August 01, 2013, 10:29:02 PM »
I have that bookmarked :)
Question - you have to cut off the clamps at either end of the spring to take it apart. What do you use when you put it back together? Or do you just leave them off?
1989 Fiat 126 BIS
« Reply #21 on: August 02, 2013, 11:18:45 PM »
You got to remove the clamps Kev, if you go back 1 page, look at the cc zero and you'll see an alternative :thumbup
kev126
  • Built not bought
« Reply #22 on: August 02, 2013, 11:34:28 PM »
I never even noticed! And that's exactly what I had in mind to do :) cheers mate
1989 Fiat 126 BIS
