Author Topic: Gearbox leaking oil  (Read 5939 times)
the duke of 126
Gearbox leaking oil
« on: June 19, 2013, 03:36:20 PM »
My bis gearbox is wet with oil , i think coming out of the driveshaft seals , is it a big job to sort the seals ? , i will prob remove the box to clean it up , is it possible to self recondition the  box ? As first is a bit whiney, this might be due to lack of oil in box due to leak?
Re: Gearbox leaking oil
« Reply #1 on: June 19, 2013, 03:48:37 PM »
I have done mine this week, apart from removing the gearbox drain plug, it is all very easy.
Marc
kev126
  • Built not bought
« Reply #2 on: June 20, 2013, 12:16:17 PM »
Happened to min, too. It's easy if you've got access to ramps. The worst part is the cost of the two seals! And just remember NOT TO OVERFILL the box with oil.
1989 Fiat 126 BIS
the duke of 126
« Reply #3 on: June 21, 2013, 11:33:39 AM »
Looking at the book , it says that the driveshaft boot seals are prob what are leaking  ? I see that there are them and a iner seal , to replace both i take it you have to remove the shafts from the box , once the covers/boots  have been unbolted , do the shafts just pull out ? The manual is a bit complicated in its description and not too clear , i looked for the oil filler plug but could not see it in the book . I would rather remove the box and do both and the two end seals , is it a fairly straight forward job ? I take it you need to support the rear of the engine by hanging it from bootlid engine bay area with a pole and chain etc ?
126blackbird
« Reply #4 on: June 21, 2013, 11:55:56 AM »
It may just be worth checking that its not been over filled, also make sure you use the right oil
jokke
« Reply #5 on: June 21, 2013, 02:20:39 PM »
what happens if its overfilled?
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #6 on: June 21, 2013, 02:28:58 PM »
You don't have to remove the shafts, just undo them at the hub ends and slide the boots off, the new ones slide back on, there is a tab on the retaining ring that must be in the right place, do up your 4 bolts, put the rest back together. You might find it easier to remove the starter, I did, needed to clean the contacts on it anyway. Only a five minute job removing or replacing the starter anyway.
Replace the split ring and little spring at the end of your drive shafts, you may as well do the rubber boot at that end as well when you are at it. Also a good time to grease your wheel bearings.
Marc
I did mine in situ with the wheel jack.
« Last Edit: June 21, 2013, 02:34:59 PM by Hazey-n-Marc »
nathanfiddes
« Reply #7 on: December 16, 2014, 09:54:07 PM »
I think I have this problem?
Split inner boot which is leaking, is it the boot that holds the gearbox oil in?
Mics126
« Reply #8 on: December 21, 2014, 06:28:06 PM »
don't forget that first gear will always whine because the gears are sliding mesch gears not helical.
nathanfiddes
« Reply #9 on: December 23, 2014, 12:55:23 PM »
Thanks, I've got some new boots now and have drained what was left of the gearbox oil in prep for the change in the new year.
Dibles
« Reply #10 on: January 26, 2015, 07:18:26 AM »
I got this to do to when the weather warms up a bit, for now it's getting topped up!
When things warm up a bit its engine and gearbox out!
Keep me posted with how you get on with it!  ;)
126blackbird
« Reply #11 on: January 26, 2015, 10:04:24 AM »
Make sure you use the right oil DO NOT USE EP OIL
Dibles
« Reply #12 on: January 26, 2015, 01:03:53 PM »
I was just going to use castrol 80/90 gearbox oil, no good??
I wanted to go 80/90 as that's what manual recommends!?
What oil should I be using? Apologies if this has been brought up before, I thought the oil was gonna be fine. Again engine oil was going to be casrol Gtx is that not any good either? :o
Sod it I'll just go with VS Max engine oil and tutela 80/90 safe bet then!
« Last Edit: January 26, 2015, 01:46:01 PM by Dibles »
« Reply #13 on: January 26, 2015, 07:28:10 PM »
80/90 castrol will be fine so long as it not EP as EP oil (extreme pressure) will knacker the syncro rings up.
Dibles
« Reply #14 on: January 26, 2015, 07:59:27 PM »
No thanks for warning I checked it out and the castrol one is EP so I'm gonna go safe and order some proper stuff from recambi, thanks for your help and warning I had no idea what the EP was all about cheers ;)
