Author Topic: Which mig welder gas or gas less  (Read 5512 times)
fixit
Re: Which mig welder gas or gas less
« Reply #15 on: May 25, 2013, 10:38:20 PM »
thanks for the offer ;D  the kettles always on
still preparing Freddie at the moment, I want to make the rear middle panel then I will have some cut offs to practice with
although im thinking of making a shelter to work in with this strange weather we having
I must admit ive put the .6 mm wire in, and threaded though the torch, wired in a massive plug, (destructions said so)  got friendly with the shroud and tips
gave the bodywork a polish so it had the wet look hehehe
just need to sort fire extinguisher, and googles for the outstanding neighbours ;D
regards f
Ruggero58
« Reply #16 on: July 06, 2013, 04:32:43 PM »
Good Choice.   For years I had an Italian made Deca welder and I ran a CO2 Argon mix also.  I bought it used for $50 from a Autobody shop that was upgrading.  I set it up with the finest(skinnyest) wire I could buy for it.   I could weld tin foil with that thing! ...almost...  The big thing is minimal heat means minimal warping.   Tack your panels first then do the full weld and that should keep your warping to zero.   Ciao for now...
