Author Topic: What did you do to your 126 today ???  (Read 168372 times)
« Reply #90 on: June 22, 2013, 11:57:54 AM »
Lucky bugger I wish I was that far along!- oh and marc on the satin black front you can always get it based black and cleared with satin laquer- a painter friend of mine did it with a set of motorcycle tins...
« Last Edit: June 22, 2013, 12:00:31 PM by stuey »
« Reply #91 on: June 22, 2013, 02:02:14 PM »
mate of mine did this with his Consul, looks spot on.
Marc
markymarc
« Reply #92 on: June 22, 2013, 07:56:40 PM »
Its lookin like the satin black will b gloss black due to the fact no-one wants to spray satin!!
Marc
markymarc
« Reply #93 on: June 23, 2013, 11:15:56 AM »
I fitted the same custom dipstick i had made for "lil rod" to my other halfs Abarth 500.
I'm in the good books ;-)
Marc
rmbruton
  • before
« Reply #94 on: June 23, 2013, 04:59:14 PM »
sanding! Aaaaargh
« Reply #95 on: June 26, 2013, 05:19:14 PM »
Finally got a tyre on one my 13x6 revo's so I could test fit it today- the are spaced more at the front so no arch problems despite being wider than my last set but they are touching the shock on the back so looks like a spacer 15mm? will be required. But at least I can check all the arch clearances so I don't destroy the tyres/arches on its maiden voyage this time! Pic!
markymarc
« Reply #96 on: June 26, 2013, 08:49:22 PM »
Booked "lil rod" for its paint. Woop woop!! 8th July.
Marc
fixit
« Reply #97 on: June 27, 2013, 01:42:08 AM »
painted bilt hamber hydrate 80 on rusty bits on front panel just to see if it works  ;D
rmbruton
  • before
« Reply #98 on: June 27, 2013, 08:58:39 PM »
More sanding
JonW126
« Reply #99 on: July 05, 2013, 12:11:16 PM »
Took the drivers seat out, didn't realise it just slides off the rail - I was looking for nuts and bolts to undo !
Will be having the drivers seat cloth material repaired next week, as its torn on the seam like most.
markymarc
« Reply #100 on: July 07, 2013, 05:46:40 AM »
I took my "lil rod" to the paint shop, can't wait to see it finally painted!!
« Reply #101 on: July 07, 2013, 10:44:31 AM »
Stuey "likes" this
popik81
popik81
« Reply #104 on: July 13, 2013, 06:35:07 PM »
Filled the gearbox with oil despite the stuck filler plug.
