Author Topic: What did you do to your 126 today ???  (Read 168692 times)
chrisrhodesinlbz
« Reply #165 on: September 02, 2013, 10:26:36 PM »
Hello, in answer to the question, what did you do to your Fiat 126 today....... I drove it home from its MOT Test, and it passed without any problems. Last two MOTs had advisory about play in Offside Rear wheel bearing, but it must have put itself right, as not mentioned!
« Reply #166 on: September 11, 2013, 11:48:21 AM »
Front panel filled and front bumper ready for paint!
« Reply #167 on: September 11, 2013, 05:41:08 PM »
 Fitted these today. Some more bleeding to do tomorrow and hopefully a test drive.
Bar Vitelli
« Reply #168 on: September 11, 2013, 09:27:16 PM »
Not me, but the missus, took the beautiful green car to work to some random meeting, turned up and the chap sat next to her only has a yellow 1974 car in storage for the last 10 years!  Already made him an offer but apparently he's not up for selling...just shows though, there are more of our cars out there hidden away than we think...
Every cloud has one...
Seabee1978126
« Reply #169 on: September 13, 2013, 08:42:47 AM »
The other day I was hearing a weird sound from my passenger front wheel.. It almost sounded like a bearing was grinding but it wasnt. After taking it apart and inspecting, my drum is warped! ??? I figure being a 1978 nothing has been touched before. So, I decided to go ahead and redo the whole brake system :P Today, 160 euro later I got new Drums, Slave Cylinder's, Master Cylinder, Shoes, and rubber lines!!!! Not a bad price I think for all them goodies! 8) This will be my project for Sunday!!!! ;D (does anybody know how much Dot 4 goes in this little beast?)
« Reply #170 on: September 13, 2013, 10:16:59 AM »
Changed the gearbox mounts yesterday. The old ones were barely hanging together. Loads better now and was very easy to do.
« Reply #171 on: September 17, 2013, 11:49:09 AM »
Just changed my quarter light, pretty easy to do if not a little nerve wracking at times.
Bambino126
« Reply #172 on: September 17, 2013, 02:35:03 PM »
Greased my King-pins.
Found out how to do this and wow what a difference - the steering is super light now. Recommend this easy job to everyone.
Somebody had fitted 3/8 inch 90 degree ones which are a pain so also ordered the correct metric ones to make this job even easier in future  ;D
Kent126
    • Facebook Profile
« Reply #173 on: September 18, 2013, 04:53:39 PM »
Today, I replaced the rear engine mount spring and rubbers on the deville. The old ones were knackered as you can see. Also did some tidying under the bonnet, and some hammeriting to keep the rust at bay.
Also found that the pipes coming down from the front windscreen drain, were just hanging down under the battery and are too short. Any water would have just been dripping under the battery tray. One has been relocated, but the other needs to be extended. Another job for the list, I also finally found time to mow my lawn too!  :P.
Piccies;
Tom
1974 Italian Fiat 126 TA
2008 Fiat Panda 100HP
Kent126
    • Facebook Profile
« Reply #174 on: September 20, 2013, 03:12:31 PM »
Put a new exhaust on today, with new gaskets and the correct exhaust bolts which were missing.
Also replaced the old knackered horn which was embarrasing, and swapped it from a spare lucas horn I had lying around.
Tom
markymarc
« Reply #175 on: September 21, 2013, 05:08:34 PM »
Drove "lil rod" to have its exhaust built/made & MOT done.  Pick it up next Friday!!
Marc
Bambino126
« Reply #176 on: September 26, 2013, 03:22:21 PM »
Changed the gearbox mounts on my BIS which as you can see were quite tired.
Kent126
    • Facebook Profile
« Reply #177 on: September 30, 2013, 10:02:05 PM »
You get by with a little help from your friends  ;D
Today, some new bits and pieces. Engine oil change, gearbox oil change, oil filter cleaned, some routine maintainence.
crap removed from filter;
Nice and clean  ;D
Organised Chaos!!
Tom
DeVilleChris
    • Club 126 UK
« Reply #178 on: October 01, 2013, 05:28:56 PM »
Looking good! you have 3 126's?
1979 Fiat 126 DeVille
1979 Fiat 900T Amigo
« Reply #179 on: October 01, 2013, 06:19:47 PM »
I stripped down a 500 and a 126 gearbox side by side to compare the inner gubbins. Some interesting similarities  :)
Rebuilt gearboxes look to be next step. 126 synchro box with Bis final drive & a standard 500 box.
