Author Topic: Little red BIS  (Read 16390 times)
madbaz
Re: Little red BIS
« Reply #45 on: February 26, 2013, 03:15:04 PM »
kev126
  • Built not bought
Re: Little red BIS
« Reply #46 on: February 26, 2013, 05:44:06 PM »
More details!
1989 Fiat 126 BIS
madbaz
Re: Little red BIS
« Reply #47 on: April 10, 2013, 08:10:56 PM »
 :o
damned weather!
Iv been busy non-the-less, fronts no where near as finished as i want at this point, and iv no got my tyres fitted yet so i cant finalise anything which annoys me but,...well make your mind up i like it...
Look at all the f****s i give  8)
Re: Little red BIS
« Reply #48 on: April 10, 2013, 08:31:23 PM »
what are those steels off of? Are they 14's? I like them.
Marc
madbaz
Re: Little red BIS
« Reply #49 on: April 10, 2013, 08:34:15 PM »
13"s from a vw bora - the tyres on them are way too big atm but yeh i realy like the wheels so their staying
madbaz
Re: Little red BIS
« Reply #50 on: April 17, 2013, 07:27:12 PM »
kev126
  • Built not bought
Re: Little red BIS
« Reply #51 on: April 17, 2013, 08:14:06 PM »
More pics!
Baz, would you be so kind and tell us exactly what you've done to the suspension? Ill be lowering mine soon :)
1989 Fiat 126 BIS
madbaz
Re: Little red BIS
« Reply #52 on: April 17, 2013, 08:50:33 PM »
fronts not finished yet...and theres not alot of metal or spring left on the rear  :$
Iv slotted the frame at the back for more clearence (rear - welded a inverted box in where there used to be a lump ) and at the front iv welded up some mounts.
extended chassis forward and down then welded up points to bolt wishbones to which i got from a quad bike, Iv also bitted another cross memeber to brace them as well as a top strut brace. Once i worked out the lengths iv lowered the car at the front to see where the coilovers (also from a quad) will need to sit and that made up mounts for the shocks to sit. The bottom of the shocks dont sit at the top of the wheel hub carrier on my car anymore, they are mounted behind it with my own custom mounts made from 4mm steel and bolted to the carrier.  Been alot of work and needs alot ofgrinding back and tidying up in places ( hence no photos as im quite embarrised by it atm. The drivers side it almost complete bar one of two more bits of bracing and the passenger side isnt far behind.
The front will come down another inch or so by the time im done.
As you can see - the passenger side wishbone i orignaly made was toooo long lol :) Iv solved that on the drivers side and need to go back over it - hours work at most.
Iv got 4 more holes to weld in the floor when thats done, a cracked brake line, then fit no'plate lamp at the back , adjust handbrake, spray the inside, and buy a hub for my wheel , other then that little list shes ready to rock ( will probably fit a big shiney chrome bike can out back and make some polly mounts for the gearbox as im not happy how much it all moves! )
...then buy a VFR engine  ::)
madbaz
Re: Little red BIS
« Reply #53 on: April 17, 2013, 08:53:15 PM »
oh yeh and its got one 145 tyre and 3 175 tyres on at the moment , hence it looking rather wird lol
pietschokkenbroek
Re: Little red BIS
« Reply #54 on: April 17, 2013, 09:19:44 PM »
This is great stuff!!  :thumbup
Looking for a VFR engine?  :secret:...
kev126
  • Built not bought
Re: Little red BIS
« Reply #55 on: April 17, 2013, 09:23:12 PM »
Some top work there mate! I'm a big fan! Can't wait to see the finished article and hopefully some pics of the set up in the neat future  :thumbup
1989 Fiat 126 BIS
madbaz
Re: Re: Little red BIS
« Reply #56 on: April 18, 2013, 12:07:49 PM »
Oooo
Sent from my moblie with my thummy wummys.
« Last Edit: April 18, 2013, 06:07:55 PM by madbaz »
madbaz
Re: Little red BIS
« Reply #57 on: April 21, 2013, 01:54:02 PM »
tum ti tum , ill just leave this here....
madbaz
Re: Little red BIS
« Reply #58 on: April 23, 2013, 08:15:55 PM »
 8)
Almost happy that i can show you guys some photos of the underneath....assuming i can get the jack in/out  ;D
