Author Topic: Alfa Romeo GTV  (Read 4667 times)
Funkin Go-nut
Re: Alfa Romeo GTV
« Reply #15 on: December 06, 2012, 08:16:31 PM »
Glad you got it sorted, you will probably think I'm nuts but I sold my 156 GTA and decided to keep the 126 because it was more fun and it was getting more use  :o
Still I bought a 156 2.0 ts as I needed something a bit more reliable for work when my 126 had some issues earlier this year and my wife uses our Giulietta for her commute.
The gta is a great car and they are no more costly to run than a standard 156 v6, they do suffer a little bit from the weight up front but the revised suspension geometry and mounting points more than makes up for it and you get much bigger brakes. You do pay a premium over the standard cars but you do get so much more...
and yes I do really miss it  8)
Re: Alfa Romeo GTV
« Reply #16 on: December 07, 2012, 08:35:20 PM »
You know what. I also use my 126 more than my Alfa! That said, both are my favorites.
I hear the 3.2 V6 engines and 2.2 JTS (both GM engines) in the Brerras are no good. Do you agree?
Funkin Go-nut
Re: Alfa Romeo GTV
« Reply #17 on: December 09, 2012, 09:25:11 PM »
The GM 3.2 is ok just a little boring compared to the "older" busso V6 (The one with the chrome intake pipes) The last iteration of the busso v6 was a 3.2 available in the GTA's, last of the GTV's and the GT.
The GM 3.2 went in the brera and 159. (It has plastic cam covers) It doesn't have the deep growl that the older v6 had but it does have quite a nice note right at the top of the rev range.
The GM 2.2 JTS suffers from a dodgy flat spot and isn't as "sweet" as the old twinspark. This was available in the BRera and 159.
They did do a 2.0 and 1.8 JTS but to be honest they are really poor so I would avoid at all costs. It was a FIAT engine and was a development of the twinspark but with single plugs per cylinder and direct injection. I have heard nothing but bad things about these engines. (they were available in the last of the 147's, the GT and the facelift 156)
The only advantage the GM engines have is that they have chains instead of cam belts.
Hope that helps  :)
« Last Edit: December 09, 2012, 09:27:41 PM by Funkin Go-nut »
Draigflag
  • Got a New Abarth 500 too!
Re: Alfa Romeo GTV
« Reply #18 on: December 10, 2012, 07:58:21 AM »
I test drove a Brera before buying the Abarth. It was awful! From then on, I decided to never buy a big car again. Keep it small and light with plenty of power qnd the power weight ratio will always work in your favour! I had a 300 bhp focus rs racing me a few months ago, he just couldnt get past despite trying to overtake twice! I didnt dare tell him I was driving a Fiat with a 1.4 litre engine!
Re: Alfa Romeo GTV
« Reply #19 on: December 10, 2012, 10:33:04 PM »
Hope that helps  :)
Yeah, I heard the same thing about the 2.2 JTS as well. The 3.2V6 is quick but heavier than the 3.2 V6 Busso engines. I hear the GM engines are not as reliable. The 159 and Brerra I have been told drives like an American car - it floats! It is a pity really because I really like the shape of the 159 and particularly the Brerra. The prices for these cars are falling, so now affordable. The Brerra shape is as attractive as the Pininfarina designed GTV.
Da Londo
    • Fiat 126 blog
Re: Alfa Romeo GTV
« Reply #20 on: December 10, 2012, 11:15:52 PM »
I also have a GTV, 2.0 TS, 2001, only 45.000km, it's great to see another 126 owner with a GTV
Re: Alfa Romeo GTV
« Reply #21 on: December 13, 2012, 10:38:59 AM »
 I`ve also got a GTV but it`s a Spider. Not sure about the mileage though and the engine size is variable...
 A picture might help ;D
Re: Alfa Romeo GTV
« Reply #22 on: December 13, 2012, 03:04:26 PM »
Mmmm failed MOT on windscreen :D
