Author Topic: choke  (Read 2076 times)
The Doctor
choke
« on: March 09, 2006, 10:20:43 AM »
Hi Everyone,
Berushka is running fine, but small problem with choke :oops:  there seems to be two fixing points, one on the carb and one just before it, seems to hold the cable in place.  Trouble is I can't take the choke fully off, so the cable isn't fastened properly somewhere.  Advice would be appreciated.
Graham
you can do it in a 126 (I have!)
PaulB
choke
« Reply #1 on: March 14, 2006, 02:38:46 PM »
I don't fully understand your problem, but the choke cable isn't working well, suspect rust or a kink. Either way, I would ditch the cable and get a new one. A kink is pretty much unfixable and though rust can be cleaned off and the cable lubed, its often a symptom of the outer casing being damaged and moisture getting in somewhere so the problem will just come back.
