I have been fiddling with the gear linkage
I want to use the aygo gearstick mechanism (which is a brilliant but simple working piece of engineering
) which in
real live the aygo is turned front to back. On the gearbox itselfs are two levers that need to be operated. The photos show the mock-up of the sollution I came up with... If I did my homework correctly
the gearshift pattern is as it should be.
Toyota Aygo shift mechanism (I still have to find a way to make the push-pull-cables longer) The photo also shows the hole I had to make to fit the alternator
I said it was just a mock-up
[youtube]http://www.youtube.com/watch?v=DcNSYk9iqCY&feature=BFa&list=ULN4J4-9nJISw[/youtube]
