Author Topic: Project 126 Aygo  (Read 76588 times)
Fiatos
    • Photoalbum
Re: Project 126 Aygo
« Reply #60 on: April 10, 2013, 10:48:52 PM »
I hope you don´t have cooling problems in Present with your rear mounted cooler.
grubscrew
« Reply #61 on: April 11, 2013, 09:17:16 AM »
.. Ive been capsulated by this guys enthusiasm, skill and above all smart thinking. What a fantastic write up.
  My wifes car is a Citroen C1, which uses ( I think), the same 3 cyl engine common rail toyota lump, and is returning 60 mpg , so you should be saving a heap of fuel. Well done. Mike.
All things Italian.
pietschokkenbroek
« Reply #62 on: April 11, 2013, 07:25:49 PM »
Thanks Tate!
Yes I know, all the choises in life.... ;) I want to give it a try first and we will see...
...  :$ ... Thank you... :thumbup
Tomasz
« Reply #63 on: April 12, 2013, 03:56:57 PM »
This is a great project! I am really enjoying following the progress.
Well done!
pietschokkenbroek
« Reply #64 on: April 15, 2013, 02:33:47 PM »
 :) Thank you all for your support!!
Well done!
There is still a lot to do, so stay tuned!!  :thumbup
Fiatos
    • Photoalbum
« Reply #65 on: April 15, 2013, 11:10:50 PM »
Nice oil pan!
pietschokkenbroek
« Reply #66 on: April 16, 2013, 01:08:46 PM »
Nice oil pan!
Thanks Phillip! I guess, in the near future I have to start washing my hands before I get to work on the car  :D
« Last Edit: April 16, 2013, 01:10:39 PM by pietschokkenbroek »
pietschokkenbroek
« Reply #67 on: April 30, 2013, 01:18:47 PM »
Been working on the gearshift mechanism. It takes time but, bespoke made parts always fit like a glove  :D.  I hope you agree it looks better than my first attempt:
Tate
« Reply #68 on: May 01, 2013, 05:59:54 AM »
Yes, it is starting to look very good indeed  ;)
Fiat 126 -73 project
2 x BMW E21
pietschokkenbroek
« Reply #69 on: May 24, 2013, 08:35:22 PM »
Thanks Tate!
I had some final welding carried out on the gearbox to get it mounted properly.
Ready to go in!
I made a bracket (mounted on the original gearbox mounting points) to keep the engine in place.
Removed the drive couplings. One has been 'repaired' using silicone sealant  ::).
When dismantling the Toyota shafts, I found this ???...
Did some cutting.. ;D
Made some measurements, did some of the remaining metal bits in a box and send it to the company who promised me to make something usable out of it! My patience is put to the test  8)
That's all for now...
pietschokkenbroek
« Reply #70 on: June 15, 2013, 10:27:16 AM »
 :D
skoda_norman
« Reply #71 on: June 17, 2013, 07:12:44 AM »
Brilliant work. Very much looking forward to seeing this finished. :)
pietschokkenbroek
« Reply #72 on: July 03, 2013, 07:58:04 PM »
Thanks Norman!
It turned out that the short shaft is not going to work.... The angles it has to make are to big for this short shaft....  :-X Cock-up!! :-X I think the only option (besides putting the old engine back in  :P) is to move the engine a little to the right  ???. So I started up the angle grinder.. Is has moved approx. 2 inches.
When is have both engine mounts in place there'll be more photos.
On with the gearshifter (plan B). I am now going for the Aygo 'cables'. But I had to come up with a adapter to change the pull in a push motion en visa versa....
« Reply #73 on: July 29, 2013, 01:22:59 PM »
Any news on the project? Darrel just posted this. http://club126uk.co.uk/smf/index.php?topic=8286
« Last Edit: July 29, 2013, 02:50:48 PM by Hazey-n-Marc »
pietschokkenbroek
« Reply #74 on: July 30, 2013, 09:35:05 PM »
After the debacle with the drive shaft, it's back to the drawing board  :P
I modified the engine mounts on the car... Another advantage is that there is now more room for the radiator.
the next hurdle is to come up with a brilliant route for the exhaust... :headscratch: (it's on the wrong side of the engine! ???)
