excellent tim!! i bet your pleased.
i had a feeling, it was thermostat casuing fluctuating tempretures.
My BIS had been in our garage for 6 years before I had the head gasket done, so it had been sat there soaked in water/oil.
When i removed the thermostat housing, it was clogged up with what looked like porridge. (deposits from where the water had reacted with the alloy engine and caused corrosion)
I always say the most reliable 126's (especialy the BIS) are the ones which have been run regularly.
i would flush your coolant out and replace with new antifreeze with corrosion inhibitor make sure this is present. (50/50 mix)
