Fiat 126 Chat
German Fiat 126 Bambino engine.
Pages: [
Topic: German Fiat 126 Bambino engine. (Read 2499 times)
Subscriber VIP+
on:
June 16, 2012, 01:57:12 PM »
Probably a question for one of our continental bros but does anyone know if the German Bambino engines were designed to run on unleaded petrol ?
Subscribers
Re: German Fiat 126 Bambino engine.
Reply #1 on:
June 16, 2012, 03:42:13 PM »
Personally (That means could be wrong)
The square heads were on the early 126s. (up to late 80s, very early 90,s) so I would be suprised if they were.
Reply #2 on:
June 17, 2012, 09:54:00 AM »
now i think we should not refer to anything german as squareheaded this is very anti...
It's Hazey's car, she does let me fix it sometimes
Reply #3 on:
June 17, 2012, 07:16:00 PM »
It's fine as long as we also talk of Roundheads to keep it balanced. eg. That Cromwell used to take things a bit seriously didn't he.
https://www.facebook.com/marc.coker
http://www.flickr.com/photos/98903134@N05/
Subscriber VIP+
Reply #4 on:
June 18, 2012, 06:44:07 PM »
Now then , now then !
Well the thing is that the Bambino head apart from being square has a number of other differences. The spark plugs fit into a deep steel liner and the head mounting stud holes also have a steel liner . So a robust build with a bit more bulk that will help to disipate heat like the Panda 30 head .
Subscriber VIP+
Reply #5 on:
July 18, 2012, 08:29:21 PM »
Thought I would bump this one up just in case some one knows the answer
Da Londo
It's not the carb size that matters, it's the jet
Reply #6 on:
July 19, 2012, 08:16:38 PM »
On a Dutch forum I read that every 126, since engine code 126 A1.076/E, may run unleaded. I also checked the German forum and after reading some posts I believe no one there runs on leaded, square or not, old or young.
http://jimsfiat126.blogspot.be/
Fiatos
Member
Reply #7 on:
July 20, 2012, 06:58:39 PM »
All the engine of the 126 can be used with unleaded fuel.
pics on:
http://philipp-scholz.magix.net/
DEYAN IYI
Reply #8 on:
July 21, 2012, 12:42:01 AM »
In the Polish sources - the heads since 1990 - appropriated for unleaded gasoline.
PS - all of the 126 are good for unleaded... Do you thing it's the main problem!?!?!?!?
Subscriber VIP+
Reply #9 on:
July 21, 2012, 06:44:06 AM »
Thanks for the input guys
It is just that I have this Bambino cylinder head which was mis-sold to me as a Panda 30 head a couple of years back. There are issues/problems with fitting this head but I think I have come up with ideas about how it can be made to be interchangeable with a regular head. The head came with a large twin choke side draft Solex (like a Weber 40 dcoe) carb & manifold that some idiot had tried to bodge fit it. I am still thinking of reviving this project and if the head is OK for unleaded fuel then that gives me more incentive
Reply #10 on:
July 21, 2012, 09:45:25 AM »
The old twin choke, side draught solex is a really good, nice sounding carb. I recommend relocating the airfilter to the back of the shed, sounds lovely there.
Pages: [
Fiat 126 Chat
