Well. I asked a friend of mine, who is running his bug with the lid open and he said that it has a great effect. Now in BG is about 35*C and the engine maintains 95*C. When closed ... 115*C oil temperature. Also said that
the air gets into the engine bay. Then I felt a bit suspicious about the 20* improvement, and found how the air comes from outside to the turbine... So, completely different story...
You can see on top of the engine room the vents:
And how the cool air enters the turbine... straight form the engine room:
Conclusion! The bug style doesn't work in 500/126 case. We need the warm air to run out, not to put cool air in the engine bay
Some more ideas. Also Porsche 911 Turbo style for low flying airplanes hihihihi
