Fiat 126 Chat
Help!!! Melty light switch!!
Pages: [
Topic: Help!!! Melty light switch!! (Read 1837 times)
It's Hazey's car, she does let me fix it sometimes
on:
May 19, 2012, 09:02:00 PM »
Rear lights and dash lights just went out and won't come back on!! Front lights are still working.
Has anyone else had this? Is it a fuse?
Marc
Last Edit: May 20, 2012, 12:36:10 PM by Hazey-n-Marc
https://www.facebook.com/marc.coker
http://www.flickr.com/photos/98903134@N05/
popik81
Re: Help!!!
Reply #1 on:
May 19, 2012, 10:23:13 PM »
90% fuse....
Re: Help!!!
Reply #2 on:
May 19, 2012, 10:37:36 PM »
Cool cheers, will check tomorrow.
Marc
Re: Help!!!
Reply #3 on:
May 20, 2012, 08:13:24 AM »
Yes proberbly the fuse as each one has a separate. Or a dodgy light switch, wiggle it as you turn it on and off and thy may come back on! I have to do this with mine!
Re: Help!!!
Reply #4 on:
May 20, 2012, 10:02:42 AM »
Are the dash lights on the same fuse as the rear lights?
Re: Help!!!
Reply #5 on:
May 20, 2012, 12:34:22 PM »
It is my light switch, one of posts inside the switch has either worn or melted. Anybody experienced this before? Has anyone got any spare broken binnicle switches (the six switches surrounded the main dash display)?
marc
Re: Help!!! Melty light switch!!
Reply #6 on:
May 20, 2012, 12:36:45 PM »
Is this likely to cause a fire? It has all of the correct fuses in place, I swapped all of the 7.5,s around a space in case I had a super fuse.
Marc
Last Edit: May 20, 2012, 12:38:19 PM by Hazey-n-Marc
Timothy
Member
Reply #7 on:
May 20, 2012, 01:31:41 PM »
what light bulbs are you using? could be drawing too much current if they are the wrong type ,causing things to heat up and melt.
Reply #8 on:
May 20, 2012, 01:41:47 PM »
Standard as far as I know,it is the rear light/dash light circuit causing problems. Headlights are standard bulbs.
I am using the top of the rear wiper switch at the moment.
Last Edit: May 20, 2012, 01:52:51 PM by Hazey-n-Marc
Reply #9 on:
May 20, 2012, 06:07:23 PM »
I would say the switch is just worn out. You can take it to bits and clean it and make it work but in the long run you will need a new one. I have been after a headlight switch for ages!
Reply #10 on:
May 20, 2012, 08:10:16 PM »
Cleaned it out, but the end of one of the plastic posts inside is missing.
I have put the top of the rear wipe/wash switch on for now.
Found a replacement now though. Luckily stuey doesn't need his anymore.
Last Edit: May 20, 2012, 08:11:59 PM by Hazey-n-Marc
Pages: [
Fiat 126 Chat
