Author Topic: 126Bis Restoration By a Beginner... (Engine Rebuild Finished)  (Read 24604 times)
naboula01
Re: 126Bis Restoration By a Beginner...
« Reply #15 on: June 03, 2012, 06:25:17 PM »
New photos tomorrow... Bad Luck camera broken :S tomorrow new photos and update i promise :S
I am in Aydın do you know? Where were you?
naboula01
« Reply #16 on: June 05, 2012, 12:10:14 AM »
Soooooo.... :D
The engine just came back from revision, finally... The man who worked on it told me that the ex-owner trated the car badly, and the garage who repaired it was a butcher... The engine is in very bad shape, and i shouldn't expect or plan to tune it :S  >:(
Anyway, photo talks better than words, just look at these old connecting rods  :o
I changed the connecting rods, new piston rings, bed for the rod(that i couldn't find so i used Renault 1,4L engine which fit ;) ), i bought a spring for the engine(there wasn't one), a full set of seals for transmission and engine, and some more that i couldn't remember...
We elevated the car with my father to work under it, but still kinda scary to get under :S
I painted the brake ans suspension just to look a little "cleaner".
I also painted the back of the car, when i was working on the electricity.
before
after
The "thing" under the fuel pump was cracked :S So we made a new one in wood ;) Cause we couldn't find another one :D
The engine support are totally homemade!!! We couldn't find(yes there is a big lack of spare parts in Turkey) new ones.
I also painted the back of the car, and i am trying to rebuild the electrical system back there but... I don't know anything about electricity and i really don't understand what is what back there so, if anyone could lend me a hand it would be greatly welcome ;)
I expect to run the engine this week, a least this weekend i hope to be driving it, wish me good luck :)
PS : DAMN this engine is a crazy thing how it was even working!!! I love this car :D
« Last Edit: June 07, 2012, 12:43:17 PM by naboula01 »
Bar Vitelli
« Reply #17 on: June 05, 2012, 09:20:17 AM »
Hi Naboula, are you using a Haynes manual to help with your restoration?  There is a section on the electrics that may be useful?  If you don't have one PM me your address and I can post one to you without charge, I've got three of them, people keep giving me them for free!  ;D
Every cloud has one...
naboula01
« Reply #18 on: June 07, 2012, 12:53:31 PM »
Haynes manuals? Do you mean the manuals of fiat for repairs? i think i have one but... i am still a newbie so... And also i have a huge exam next week so i don't have time... :( But i'll PM you for more info ;)
Yesterday we finally finished the rebuilding  :P  :D Finally!!!!!
So here is the transmission
The engine as it came back from repairs...
The upper engine
While installing the engine we had big problems with bolts and bolt holes... i had to change like 30% of the bolts and remake some holes because either they were missing or the were as flat as a table...
Like the upper engine the bolts weren't fitting so we put a long M8 stick in it and completed it with nuts
Annnnnddddd.... Here is the fianl sate of the engine painted with can sparys ;) Hope you like the colors :D
I expected to get the car ona test run in a couple of days, i'll surely take a Vid of it and share it if it work, and share it again if it doesn't... So see you soon... very soon :D  :P
naboula01
Re: 126Bis Restoration By a Beginner... (Engine Rebuild Finished)
« Reply #19 on: June 07, 2012, 12:58:55 PM »
Also i forgot to told, we had a problem with the charger, it's "rope" was touch rubbing the engine, we discovered that this was due to some bolts... the ex-butcher might have dismounted it, and while resaambling it, he didn't put it correctly, so it was skewed... We just dismounted the cap and refitted it, and it was gone :D
naboula01
« Reply #20 on: June 08, 2012, 06:33:02 PM »
Just bought a used Ditributor, and installed it!!! Ready to hit the road after i installed the engine on the car, and see if anything is wrong... Wish me good luck, because this weekend we'll see if i am a good at rebuilding cars :D
« Reply #21 on: June 08, 2012, 06:33:56 PM »
Best of luck, let us know how it goes (good or bad).
marc
Emin
« Reply #22 on: June 08, 2012, 08:09:01 PM »
Good luck mate!..
popik81
« Reply #23 on: June 09, 2012, 12:00:20 AM »
where is your roof??
« Reply #24 on: June 09, 2012, 05:59:36 AM »
Best of luck I think that you have done an amazing job under difficult circumstances  :)
« Reply #25 on: June 09, 2012, 04:30:20 PM »
Loving the wooden fuel pump spacer!
« Reply #26 on: June 10, 2012, 09:29:25 AM »
I second that!  Good Luck!
naboula01
« Reply #27 on: June 10, 2012, 09:17:55 PM »
After a long day here i am... Quite desperate and sad, but still i have hope... We refitted then egine and all the electrical stuff etc, but... the engine doesn't work, we tried every thing we could thought but unfortunately it wasn't working... So we put some gas in the carb and here it goes!!! So know the engine is ok but we fuel pump isn't working, it isn't pumping... When we pull on the gas tube it is like there is a hole somewhere and air is coming from somewhere... however we checked every tube and all of them are ok... so we'll certainly dismount the pump tomorrow... Anoyone has this kind of prob or any advice?
« Reply #28 on: June 11, 2012, 06:24:29 AM »
Did you check the amount the fuel pump actuating / push rod sticks out from the spacer and gaskets. If the Bis is like the aircooled engine, off the top of my head , the rod should stick out about 1.5mms on the low side of the cam and 4mms on the high side.
« Reply #29 on: June 11, 2012, 09:09:25 AM »
Are you using proper fuel line clamps? Jubilee clips do not close round and allow air in. Is the pump diaphragm ok? You have got enough petrol in the tank haven't you? ;D
Marc
