Author Topic: This and that  (Read 5237 times)
Re: This and that
« Reply #15 on: March 22, 2012, 07:36:42 PM »
There doesn't seem to be many long jobs on a 126 except body repair. Just the normal carb/points related hard to identify problems, try one thing (30 mins) if it doesn't work, try something else (30 mins) the next day.
Draigflag
  • Got a New Abarth 500 too!
Re: This and that
« Reply #16 on: March 28, 2012, 09:09:11 PM »
Coil, condenser and fuel pump the 3 main suspects then. They cost £85 all together, is it worth me just changing the lot?
Re: This and that
« Reply #17 on: March 28, 2012, 09:20:21 PM »
as long as your fuel lines are all good and tight and put two new clear fuel filters (under 2 quid each + fuel line clips 25p each) in (one before the pump, one between pump and carb), get someone to crank it over for a minute when you watch the filters, if you get fuel in a filter, your pump works.
I have also put one on the return line, I had a split in the top section of the pipe and didn't want to replace the whole thing until I change the tank (tomorrow!! cheers Stuey (again)), so I used a spare filter as a join in the pipe. I have found that this lets me see how much extra my pump is pumping (seems a bit much at the mo, may increases the gasket size under the pump), will be leaving it in now.
Marc
« Last Edit: March 28, 2012, 09:26:48 PM by Hazey-n-Marc »
Draigflag
Re: This and that
« Reply #18 on: April 14, 2012, 08:25:35 AM »
I'm beginning to think it might be electrical now. Really struggles to start now, i usually end up draining the battery until it's dead. But then when the battery is fully charged, it starts in a milli-second on the first turn! What could that indicate?
She broke down day before yesterday, luckily the neighbour was passing and he towed me up the hill. I'm refusing to use it now until it's fixed, it's embarrassing braking down, girlfriend found it hilarious... :$
Re: This and that
« Reply #19 on: April 14, 2012, 09:44:27 AM »
If your battery is losing power it will give a weaker spark when starting. Is your battery beyond it's best (if you haven't changed it it could have been on there since last century), Or is there a power drain? Power drains are normally caused by aftermarket stereo or alarm fitments, so they are easy to disconnect to see if the problem goes away. If none of that works, you will need a multimeter, fuse plyers, and a mate (might not need a mate on a 126 ). Good luck.
Marc
Draigflag
Re: This and that
« Reply #20 on: June 22, 2012, 11:36:47 AM »
2 years later, think I've fixed it!!!
Finally found 10 minutes spare to swap the fuel pump. The underside of the old one was caked in yellow/brown rusty oily crap, the spring on the trigger mechanism was knackered so i think this was causing the problem. I cleaned it up and then fitted the new one but after draining the battery again trying to start it, i realised there was still a problem. She just wouldn't fire up, but i could smell fuel so i knew it was pumping through.
Anyway, luckily my Dad's had a few old cars, he looked and said you haven't moved this thing have you? pointing to the black disc thing next to the pump (which i had to loosen and turn to get to the fuel pump bolts) Little did i know that this controlled the spark timing so even turning it a tad had knocked the timing out!
So she runs now and i've done a few laps of town with no problems so far. Hopefully this is the fix she needs and i can start to use her more now....once it stops raining!  :D
Re: This and that
« Reply #21 on: June 22, 2012, 11:39:49 AM »
I did the same when I did my fuel pump. Pleased you got it going. Was wondering where you'd got to.
Marc
Re: This and that
« Reply #22 on: June 23, 2012, 08:09:13 PM »
Yeah, I was wondering as well. Well done! Pleased to know that your 126 is now sorted. Shall we be seeing you at Retro Rides Gathering?
« Last Edit: June 23, 2012, 08:11:15 PM by Amateb8 »
Draigflag
Re: This and that
« Reply #23 on: June 24, 2012, 04:53:28 PM »
Well not sure about that. Living in the middle of nowhere, i'm miles or hours away from anything big!
Done 50 miles in the 126 today, didn't miss a beat  :)
Also, done 1000 miles in the Abarth 500, just in this week!  :o
Re: This and that
« Reply #24 on: June 25, 2012, 10:51:29 PM »
Take your Fiat Abarth the RR then!
