Author Topic: Weber 30 dgf mixture screw?  (Read 4472 times)
« on: February 20, 2012, 09:41:40 AM »
Any chance of some clues as to where to find the mixture screw on a bIS (weber)? (I haven't actually looked yet, going out side in half an hour to poke it with a stick, and hoped one of you lovely people could help reduce my searching time :D).
Marc
Re: Weber 30 dgf mixture screw?
« Reply #1 on: February 20, 2012, 09:59:55 AM »
Taken from the Bis Manual
« Reply #2 on: February 20, 2012, 11:55:57 AM »
Cheers Chris. It would be on that side wouldn't it.
Marc
« Reply #3 on: February 20, 2012, 07:05:38 PM »
On the subject of the BIS carb, could you fit a screw, marked in red on the pic, to make the 2nd choke open sooner?
« Reply #4 on: February 20, 2012, 08:52:38 PM »
getting the second venturi to open sooner would probably (not definitely) limit how far the first would open, I had the second seize up a while back, which prevented the first opening fully. To get it to open sooner you would probably have to make it open slower (bear with me) by increasing the distance of the link from the pivot on the second, giving you a more graduated pull starting sooner. I'm sure someone else could explain this better, or tell me I'm wrong (not unusual :D)
Marc
« Reply #5 on: February 20, 2012, 09:03:14 PM »
That is the good side!! Yay!! Too used to rebuilding vacuum linkages on the other side, got confused ;D
Also, I have completely forgotten my password for the subscribers section manuals :$
Marc
« Last Edit: February 20, 2012, 09:07:12 PM by Hazey-n-Marc »
« Reply #6 on: June 12, 2012, 08:53:16 PM »
It says FIT THE REV COUNTER, what rev counter?
Also could you tune it using this method as I don't have C02 Probe :
http://www.justbrits.com/Articles/TuneWeber.html
« Last Edit: June 12, 2012, 08:55:56 PM by ciaoflyer »
« Reply #7 on: June 12, 2012, 08:56:27 PM »
I assume they mean a sun tune gizmo for tuning the carb.
