Author Topic: Washer Pump  (Read 3296 times)
Re: Washer Pump
« Reply #15 on: January 29, 2012, 09:27:44 PM »
Lina , I think I got a glimpse into the future  ;D
I already packed the pump this morning. When you said you were getting wet from the pump I assumed you meant from water at the conections, which without the valve would just run back down. If you meant water leaking from the rubber push button then it is obviously knackered.
I will post the pump in the morning.
