Author Topic: Check this next clutch changing time  (Read 2523 times)
punkydog
« on: January 30, 2006, 07:25:49 AM »
The rattling noise coming from my Bis engine, hence my reason for pulling it, appears to have been coming from the bellhousing. The clutch was slipping and juddering – nothing new there for an old 126.
It appears that the bronze bushin the back of the release bearing sleeve had worked it self loose, rattling on the input shaft, allowing the input shaft to wiggle about and destroy the crank bearing.
This what the bearing should look like.
The input shaft is held by a splined sleeve at the gearbox end and this does have some play in it so the input shaft is supported mainly by this bush, obviously the crank end bearing isn’t enough on its own. This wiggling also damaged the oil seal so the bell housing was full of oil.
The release bearing sleeve is fairly easy to remove from the bell housing after the clutch release bearing is out of the way, the seals and bushes are quite cheap, or you can get the whole unit.
 The crank bearing is a *** to remove  as it is pressed into the end, in my case I am going to have to get a machine shop to drill it out.
So, it is worth checking the condition of the bronze bush and seal next clutch changing time.
Brian
hudsonhenry
    • http://www.retro500.com
« Reply #1 on: January 30, 2006, 09:35:52 AM »
I am told that the way to remove the crank spigot shaft bearing is to fill the centre with grease, find a piece of bar (14mm I think) thats a snug fit, put it in the centre and hit it with a hammer, if the fit on the bar is tight enough the grease should push the bearing out.
Hope it helps
Nigel
« Reply #2 on: January 30, 2006, 04:22:56 PM »
Yes I can confirm this trick works, it's like magic!
Quote from: "hudsonhenry"
Hope it helps
Nigel
