an up-date, and the plot thickens. Coil, dizi, plug leads, spark plugs etc are all connected but off the car, then i connected the +ve side on the coil to the +ve on the battery and the body to earth and turned the dizi by hand fast and i get a spark!!!
Next step was to connect the lead from the ignition at the back of the car. Again turned by hand, and i have spark! This looks promising i thought.
Bolted down the coil in it's place, again turn the dizi by hand fast and i have spark. Put the dizi on the block cranked the engine with ignition on, NOTHING no spark at all (with spark plugs out of the engine of course). Took it off, turned it by hand and guess what.... it sparks. At around mid-night i gave up... So the starter does not turn the engine fast enough perhaps? It sounds ok, in terms of cranking speed, and the car always started ok on points.....I'll check the voltage reading before and after cranking the engine, and see how that goes.
Any ideas out there? Please? this is driving me mad!
