Author Topic: Fiat 126 -73 restoration [ Now: It's ALIVE...!!! :) ]  (Read 118400 times)
Tate
Re: Fiat 126 -73 restoration [Now: Bodywork]
« Reply #90 on: August 08, 2012, 08:02:07 PM »
Ohhh I like that a lot, please tel me you not gonna scrap it. That thing is so rare, it would make a great Fiat service van... 8)
Yes.. I will scrap it. :$ It's so rusty that there is no sense restoring it.. You can come to Finland and pick it up for free  ;D
Fiat 126 -73 project
2 x BMW E21
Tate
« Reply #91 on: August 11, 2012, 07:05:14 PM »
Today I removed the 903cc engine from Fiorino.
No mercy!  ;D
After removing drive shafts, hoses, wiring and bolts it was time to lift the 903cc engine + gearbox from the car.
Then I made the first test to see how the engine fits to the engine bay. Looks good :)
2 x BMW E21
Tate
« Reply #92 on: August 16, 2012, 06:07:03 AM »
Nothing special has happened.. I have been designing and fabricating the fastening points for the Fiat 127 engine and Fiat 600 gearbox.
2 x BMW E21
Tate
« Reply #93 on: August 18, 2012, 08:27:56 PM »
Asked if my friend would make one sleeve for me with lathe but he made four of them:
Parts from laser cutting company (design by me):
Universal rubber supports for Fiat 600 gearbox:
2 x BMW E21
Tate
« Reply #94 on: August 18, 2012, 08:32:49 PM »
Today I started to make the fastenings for the engine and gearbox. Gearbox is now already attached but unfortunately didn't remember to take any pictures of it..
For the engine I fabricated this kind of support plate:
Some welding...
More welding..
This is how I left the car today. Engine mount needs still some work to be finished.
2 x BMW E21
KAL SPL
« Reply #95 on: August 19, 2012, 03:38:34 PM »
Deffinately unique !
Aus's cleanest Niki !
Tate
« Reply #96 on: August 19, 2012, 08:24:49 PM »
I dont know about unique but when you do stuff by yourself - you get what you deserve!  :$  ::)
Today I continued fabricating engine mount.
Welded it together:
I tried to fit the engine and gearbox so that nobody could not see it from outside but it seemed almost impossible. So I had to make some room for it and chop the orginal rear beam.
So I cutted it until there was just enough space for the engine and made this kind of frame:
Then I started welding sheet metal:
And here it is after welding:
Engine sits quite nice there.. as it would be ment to be there?  ;D
2 x BMW E21
Fiatos
    • Photoalbum
« Reply #97 on: August 19, 2012, 09:54:52 PM »
It looks like good with your 903ccm engine. I did it in 2006 with the original Fiat 126 gearbox.
Uploaded with ImageShack.us
Tate
« Reply #98 on: August 21, 2012, 07:49:59 PM »
Bought today a used exhaust silencer... Yoshimura  ;D
Engine fits quite nicely but starter won't fit to its place. In Fiat 600 it is in top of gearbox so I had to make some room for it.
Here we go....
I decided that I make so much room that it is possible to remove the starter without removing engine/gearbox.
Hole from inside the car:
Next step is to fill that hole and make some reinforcement arouind it as I cutted quite important structural element from the car.
2 x BMW E21
Da Londo
    • Fiat 126 blog
« Reply #99 on: August 22, 2012, 09:44:53 AM »
Very nice work, it's inspiring.
Tate
« Reply #100 on: August 22, 2012, 08:20:29 PM »
Thanks for the compliments! Gives me more energy to work with this car.  :good:
This evening I made some progress because I filled the starter hole from inside. Next step is to fill 2 holes from under the car and make some reinforcements.
Now it is possible to remove the starter without removing engine/gearbox. Makes service a lot easier. :$
2 x BMW E21
Tate
« Reply #101 on: September 09, 2012, 06:47:00 PM »
Last couple of weeks I have been just finishing the body before new paint. There have been so many small things that they are making me crazy..  :-X
Today I fabricated a place for the radiator which is from Vauxhall Nova. I hope that my design works as I am going to use the orginal air cooling duct to lead the air from the side ducts to the radiator. Then I lead the air from radiator to the orginal holes which are in the engine lid.
This is where I started from:
Then I bought the radiator:
Two new fans:
Fans installed to the car:
Radiator installed:
2 x BMW E21
KAL SPL
« Reply #102 on: September 10, 2012, 12:01:29 PM »
That's thinking outside the box !
Tate
« Reply #103 on: September 11, 2012, 08:10:51 PM »
Thanks.. but thinking outside the box also means that you have to face all the new problems.. As now I'm thinking how I will solve/implement radiator expansion tank as there is not so much space for the tank  :(  :-X
2 x BMW E21
Tate
« Reply #104 on: September 12, 2012, 05:49:53 PM »
I think that I have solved the problem which I told about in the last message. I will install in-line coolant filler neck to the upper coolant hose and add a overflow resevoir tank. That seems to be the best solution.
2 x BMW E21
