Author Topic: Where do I get these wheels/rims?  (Read 5285 times)
Abiella
    • The Box Collective
« on: October 18, 2011, 11:26:51 PM »
Hi guys,
I love these old classic wheels/rims. Does anyone know how I can get them?
I accept that they are probably quite expensive!
Abiella
I drive on Button Moon...
Re: Where do I get these wheels/rims?
« Reply #1 on: October 19, 2011, 06:48:47 AM »
To fit those on a later 126 you would either have to buy a full set of hub adaptor plates or change your stub axles, rear hubs and all your brakes. Those wheels were fitted to the 500R (3.5J) and 126 (4J)
Abiella
« Reply #2 on: October 19, 2011, 09:17:39 AM »
That sounds complicated!  :o
DEYAN IYI
« Reply #3 on: October 19, 2011, 01:07:41 PM »
Yes, it's a step backward in the evolution :$
But you can trick it with adapter plate that use to fit the old type rims on 4x98mm disc brakes.
http://www.fiat500sport.com/brakes/brake-rotors-flange-to-apply-500-steel-wheel-0190.html
The bad thing about that wheels is that's almost 100% impossible to find a workshop to make you balance.
jokke
« Reply #4 on: October 19, 2011, 05:12:09 PM »
hohohoho.. :)
1980 Mazda RX626
1985 Mazda RX7
1998 Fiat 126p V6
« Reply #5 on: October 23, 2011, 11:18:17 AM »
Nice one!
« Last Edit: October 24, 2011, 09:09:07 PM by Amateb8 »
« Reply #8 on: October 24, 2011, 09:05:50 PM »
 Those rims do come up on eBay UK quiet often for about £30-40. I`ve got 3 sets ;)
 The problem is those adapter plates. They seem to be 70 Euro a piece :o
Abiella
« Reply #10 on: November 09, 2011, 02:33:25 PM »
Hi 1973/126
Would I need adapter plates for those?
Thanks,
Abiella
DEYAN IYI
« Reply #11 on: February 22, 2012, 02:46:27 PM »
wuszy
« Reply #12 on: May 01, 2012, 10:20:24 AM »
The rims you want came as standard on the  1973/126
i have a 1978 126p on this rims.
fei
« Reply #13 on: May 14, 2012, 12:35:46 AM »
I really wants the old 500 style wheels on my air-cooled, why are these wheel/adapter plates impossible to balance?
« Reply #14 on: May 14, 2012, 01:11:38 PM »
Those rims were produced in 3.5J width and fitted to the Fiat 500R and 4.0J for the Fiat 126. So if you are buying some I would not recommend the 3.5J for a 126. Those adaptor plates are a heavy duty bit of kit and do not do much for your unspung weight at the wheel. If you want balance them then you should have them balanced fitted to the wheel & tyre  :)
