Author Topic: Monster Mouse  (Read 11540 times)
Re: Monster Mouse
« Reply #15 on: April 09, 2012, 07:50:00 PM »
Nice build but don't get me wrong - you did this to a 1974 Fiat 126? :o
Re: Monster Mouse
« Reply #16 on: April 09, 2012, 08:26:23 PM »
All parts were sold, The interior went to a very good home.
Da Londo
    • Fiat 126 blog
Re: Monster Mouse
« Reply #17 on: April 10, 2012, 08:33:01 PM »
Will follow on Twitter
James.
Re: Monster Mouse
« Reply #18 on: April 16, 2012, 09:55:02 AM »
Looks awesome!
Quick question, what engine and box combo did you end up using?   :P
t66
Re: Monster Mouse
« Reply #19 on: April 16, 2012, 09:54:22 PM »
TTS built Honda Blackbird Rotrex engine, dry sumped, balance shafts removed, JE pistons, dyno run at 330bhp.
Axle is a Quaife Powertec the same as a Radical SR3, mine actually came from a Darrian T9.
Has a reverse gear on it too, and a spare set of lower ratio gears too.
t66
Re: Monster Mouse
« Reply #20 on: April 27, 2012, 05:27:42 PM »
Dry sump tank bracketed & fitted. Chargecooler mounted on the chassis back legs.
Ps I have the old steering column from the car on Ebay if anyones interested.
KAL SPL
Re: Monster Mouse
« Reply #21 on: April 29, 2012, 04:38:42 PM »
330hp in what 500kg car ? GTFO  :o
Aus's cleanest Niki !
t66
Re: Monster Mouse
« Reply #22 on: May 02, 2012, 08:32:15 AM »
It has a DTA ecu which I understand can run two maps, so I am rather hoping to have a max power setup and also a sensible one, if thats possible with this car. The original plan was to use a Hayabusa or ZX12 engine, then this very special Blackbird engine appeared. So what started as a bonkers project, took a twist I wasnt expecting. But I go with the flow....I will be happy with 600kg
Im messing on with cardboard mock up fuel tanks at the moment, looking for 25-30litres. Home grown alloy tank, positioned on the O/S/R of the car. Foam filled, baffled with internal swirl pot.
The exhaust manifold will be a stainless 2" system, 4-1 with cat, lambda sensor bung & egt probe. The silencer will lie horizontally across the back of the car, inside the cars floor line behind the lower edge of the bootlid. The related oil coolers will sit above that. Eventually the car will run with the lid open Abarth style on stay rods.
The engine bay is taking good shape, and I have an idea in my head where most of it is going to fit. The water methanol injection kit came with a big tank, so will need swapping for a smaller one.
poxxxy
Re: Monster Mouse
« Reply #23 on: October 10, 2014, 07:44:52 PM »
Very nice... has anything progressed since 2012 I wonder... Thanks for the link Pete :D
Mics126
Re: Monster Mouse
« Reply #24 on: October 10, 2014, 08:45:33 PM »
same question here, i'm sure we are all intrested to se any results.
Mike
Re: Monster Mouse
« Reply #25 on: October 10, 2014, 09:20:19 PM »
Send T66 a PM you don't no you might get an answer :D
