Author Topic: Cooked the Little One and now  (Read 4000 times)
Re: Cooked the Little One and now
« Reply #15 on: January 29, 2011, 01:18:39 PM »
This is what mine is like on idle (it does rev a bit high on idle):
http://www.youtube.com/watch?v=l_FN4TNm2io
There are lots of  other vids on youtube to compare your engine sound to.
skelz
« Reply #16 on: January 29, 2011, 01:49:52 PM »
my engine does seem to have a pop to it
« Reply #17 on: January 29, 2011, 02:15:17 PM »
It may be worth checking the carburettor bakelite insulator, they do tend to crack. Other things to check are the gas safety devices (hollow bolts) located on the cylinder head, check there is no gas escaping from these bolts if so this indicates a blown head gasket.
Have you checked the contact breaker points and then the ignition timing? which should have been the first check.
And like other are saying also check the valve clearances.
skelz
« Reply #18 on: January 29, 2011, 05:15:04 PM »
Clean idlejet earlier on .. its gotta 123 ignition in it and I am thinkin it might need a setting change.. When I get some time I am taking it too the fiat doctor !
