Author Topic: Rear main bearing  (Read 5506 times)
Re: Rear main bearing
« Reply #15 on: December 07, 2010, 09:56:33 PM »
Pete have you not fitted needle roller bearings on your bis and they work fine?
I did try the needle roller bearing at the rear of the engine, had the bearing cap machined out to fit and left a 1.5mm shoulder on the outside of the carrier so the bearing wouldn't work loose to the rear oil seal, the bearing had a centre hole in the outer casing which was pressed in with bearing seal and aligned with the oil channel in the block, It worked well for 200 an odd miles then oil started to pour out of the rear seal, when i took it apart the bearing outer case had worked loose in the bearing cap, and had worked through the shoulder then pushed the rear oil seal out, so not very successful :( Don't know if it was something I did wrong :undecided2: but it nacked the crank so reverted back to the standard bearings and a spare crank I had [-/
Darrell, Who do you think planted the Seed, Sorry Steve :wink2:
« Reply #16 on: December 07, 2010, 10:42:17 PM »
Wasn't me :oops:
I only planted Radishes, Pumpkin, Beans, Peas, Letteuce, Cabbage, Tomatoes, Sugar beet, Peppers and Aubergines this year :oops:
smallcox
« Reply #17 on: December 12, 2010, 09:26:19 PM »
Great one Darrell, if you send me some Radishes they may just work as bearing and the Letteuces will give it that crisp response it needs 8)
andyowl
« Reply #18 on: January 09, 2011, 10:35:06 AM »
Ref Darrell post of 30 Nov '10.
As a newbe on this forum I am very pleased to find your list of "what to do" to strengthen the engines! Very helpful! Thanks!
We have had an "A" reg 126 from new but the gov'nr won't let me use it for "AutoSolos" (driving around a tarmac course set out with cones.) So negotiating for a pre-1981 126 at present with a plan to use a spare Shorrock Blower to improve the power output. Got to show those Spridgets how it can be done without conforming!
Engine strengthening will be a very good idea!
Thanks again
Andy
