Problem solved.
This thread should have been titled " what happens when you recondition a starter motor and don't put it back together properly."
Having taken the motor out and bench tested it like you suggested i noticed that the dog gear on the starter was not travelling the full distance to the end of the shaft.
It turned out that when reassembling the starter i put the plastic fork lever in upside down.
Nothing to do with the solenoid, it was working perfectly well.
It is all making sense now.
One thing that did disapoint me was the fact that when removing the brand new solenoid from the motor the plastic casing fractured and broke into a hand full of pieces.
At least the car now starts as it should.
4 hours spent messing about on the frozen ground.
Expecting more snow tommorrow.
