Author Topic: starter soleniod  (Read 6620 times)
kumar
Re: starter soleniod
« Reply #15 on: November 25, 2010, 02:03:46 PM »
so is there no solenoid on the older ones?
i was just pulling the lever by hand from underneath, that could have resulted in a bit of a shock. :o quite literaly.
« Reply #16 on: November 25, 2010, 02:39:00 PM »
I think that Darrell is suffering from nicotine withdrawal symtoms  :o
You do not wanna be pulling on that starter lever when the engine is running as you will knacker your starter motor bendix and starter ring.  :oops:
If you can only bump start the car then the starter motor will work then it it could be a couple of things. Loose fan belt so little charge in battery, poor battery condition , Poor earth & battery connections all the way through & finally worn starter motor.
You do not have a solenoid.  On the later cars the solenoid does the work of the earlier pull switch  [-/
« Reply #17 on: November 25, 2010, 04:38:16 PM »
NIcotine withdrawal has got bugger all to do with it.
It happens to mine from time to time that the starter is a bit stiff to engage and needs that extra force to get it to crank hence I say try a piece of WOOD to avoid shock etc to apply the extra force.
And yes I was replying to your post where you said ' is this likley to be anything to do with the starter solenoid?'
If it works sometimes and not others, specifically after the unadvisable engagement of the starter when the engine is running, I dont see how the battery condition earth and fan belt can have anything to do with it.
Perhaps a qualified mechanic will be the best cure...now there's a bit of nicotine withdrawal!
« Reply #18 on: November 25, 2010, 05:43:32 PM »
Could also be the connector under the button on the starter (the copper one with the thread coming out to which the leads are connected to) that is worn and doesn't connect properly. If you're lucky it might be worn on one side and can be turned over.
« Reply #19 on: November 25, 2010, 06:14:31 PM »
OK let's break it down into smaller chunks . If the battery is starting to fail & this is the time of year for it then it may not pack the punch to turn over the starter motor. If any of the connections in the main power circuit are poor then the starter motor may not work. So you have battery connection to earth on the main frame , battery lead to the starter motor and I have encountered bad corrosion at the starter switch connection in the past. Then the earth strap back to the main frame. A slightly loose fan belt , especialy if you are running an alternator , will produce enough power to put out the ignition light but not enough to recharge the battery. A short run after a bump start could well just trickle enough juice into the battery to energise the starter.
When you pull the starter lever it brings two large copper contacts together. If they do not meet properly & are worn or if the cable is not well adjusted they will arc and further damage the contact faces and you are on a downward slope. That is why , if you use a piece of wood , you can get more force on the starter switch lever than you can with the cable & starter lever. If you use a metal push rod & connect with the main power terminal on the starter you will short out the battery to earth very easily and produce a bit of a light show but you ain't gonna get electrocuted with 12 volts .
I use my silver capped walking cane with the rubber foot on such occaisions  ;D
« Reply #20 on: November 25, 2010, 06:23:30 PM »
Like Dr. House huh?  ;D
« Reply #21 on: November 25, 2010, 06:42:22 PM »
There you go, buy a new battery new starter, new cables and a piece of wood.
Funny still my point has not reached home.
SOmetimes the mesh of the starter doesnt quite line up for some odd reason I havnt quite figured-out. The battery can be brand new as mine is and fully charged but a little more force will be required.
« Reply #22 on: November 25, 2010, 07:28:01 PM »
 :D you can't mess with the mesh  :o
It is all lined up. If the bendix does not align with the starter ring then you have major problems  :oops:
If you have very worn parts in that department then the starter motor can jam. Then you have to put the car in gear & try & push it to & fro until it releases  :)
As GTMaster says the copper bolt can be rotated to get a good contact as a short term fix  [-/
Dr House is a lightweight in the stick department , I save my ebony diamond encrusted wand for special occaisions  </4 </4 :beer: </4 </4
« Reply #23 on: November 25, 2010, 07:44:36 PM »
Its not possible but I've tried 3 starters and 2 flywheels and now a diferent bellhousing. So what other serious problems can there be?
Sometimes the energy required to get the starter to work is more.
« Reply #24 on: November 25, 2010, 07:47:55 PM »
Ps thought it was the cable and changed that too
« Reply #25 on: November 25, 2010, 07:48:57 PM »
Oh and bettery is new as of about three months ago, Bosch battery as thought it might do better than a Halfrauds one
« Reply #26 on: November 25, 2010, 07:51:00 PM »
Earth strap was replaced about 6 months ago and stainess nuts and washers used to fix to to body.
Also done quite a bit of work on connectors to try solve indicator slowing issues however seems I am not the only one who has this so that seems normal
neil 126
« Reply #27 on: November 25, 2010, 07:56:59 PM »
Have you checked that there is 12v on the small wire that connects to the solenoid when you turn the ignition to the start position ???
Hi Pete,
I have not tested it as i have no testing kit.
I could test it by simply running it to one of the rear light bulbs.
I did replace the female connector at the solenoid end as it fell off in my hand when i first noticed the problem.
Where does this wire run from? Is it from the ignition barrel?
I bought a new solenoid from 126fan so i cant see it being that the solenoid is afulty.
Any and all help appreciated.
I hope i can get this fixed befor the snow storms catch me.
learnt it the hard way
« Reply #28 on: November 25, 2010, 10:03:50 PM »
Hi Neil, Just can't believe that a fiat 126 owner hasn't got a 12v circuit tester :D the best 3 quid you'll ever spend [-/
The wire runs to the ignition switch and then to the fuse box, If you have a short piece of heavy duty wire about 10cm long you can short it across the large terminal (which is a permanent live) to the solenoid terminal for a few seconds, this should activate the solenoid and the starter motor should turn. If it turns the problem is the wire back to the ignition switch, Or the Ignition switch itself.  Beware Make sure the car is in neutral before you do this We don't want you running yourself over :D If you take the air filter box off you can reach these terminals from the top [-/
« Reply #29 on: November 26, 2010, 09:03:22 PM »
just as a little detour from the main point of the thread but... i kept snapping starter cables so i bought some steel wire rope from a diy superstore along with some mini clamps and then fabricated a super strong starter cable it never broke and it did not suffer from stretch....just a thought. i agree with pete sounds like the wiring has gone wrong somewhere can you take the starter off and bench test it?
