Author Topic: starter soleniod  (Read 6618 times)
neil 126
starter soleniod
« on: November 13, 2010, 11:52:01 PM »
I know there has been a thread going about starter motors recently but i have been looking for over 2 hours and i can,t find it.
I have been having trouble with starting recently.
I have had the starter off a few times, cleaned the comutators and bushes and the starter motor now turns very freely and is nice and strong.
The gear has been cleened and slides on the shaft freely and does not stick.
I have checked all connections, power and earth to the body, taken them back to clean metal and reasembled.
The problem that i have is that the solenoid is not working.
It does not pull the plunger in and force the starter gear on the motor into the teeth on the flywheel.
I have had the solenoid seperated from the starter and cleaned all contacts but still nothing.
My understanding is that the solenoid is nothing more than an elecromagnet that operates when charged at startup only, given this what could have failed on it.
I have tried to open it up to investigate but it looks like there may be need for some serious soldering equipment for this.
learnt it the hard way
Re: starter soleniod
« Reply #1 on: November 14, 2010, 08:09:54 AM »
When you start the car, is there a clicking sound?
hobbs126
« Reply #2 on: November 14, 2010, 12:33:34 PM »
well if u want to send it to me ill look inside the solenoid and replace the contacts , thats what i do for a job
neil 126
« Reply #3 on: November 14, 2010, 06:56:42 PM »
Hi guys, thanks for the responce.
There is no clicking from the solenoid or starter.
The starter does turn (very fast, now that i have cleaned up the contacts), and i am able to start the car( only on about the 4 or 5th attempt) but i think that the gear on he starter only moves along the shaft due to its momentum on the slow down, and it only just makes it into the teath on the flywheel.
Is it something that i can fix?, I do have soldering kit but it is only a small hobby thing. I can get a better one off a neighbour if needed.
I may take you up on your offer (hobbs126) if i can not do it myself.
What would your terms be?
neil 126
« Reply #4 on: November 15, 2010, 07:52:47 PM »
After my near death experience this morning as the car ran me over as i tried to push start and slipped on ice. i have decided to by a new one from 126FAN i have also ordered a few other service spairs.
Thanks guys for your offer of help, but today was the last straw and i had to do something.
I may well trie and fix the old one but need something quick.
The weather is getting cold up hear and i dont fancy having to push start the car in the ice again.
P.S. I don't hink anyone saw me as i was laid on the ground as the drivers door ran me over and squashed me to the ground.
« Reply #5 on: November 15, 2010, 09:30:56 PM »
Neil , I loved your story but if you were a modern man you would have captured your near demise on your mobile and posted it on that "Tube" thing for us all to enjoy  ;D
Could be that your car has got it in for you  :oops:
Just a theory but don't get all solenoid about it  [-/
neil 126
« Reply #6 on: November 15, 2010, 10:36:55 PM »
I think it is safe to say that i am definately not one of these modern men.
What is this "tube " thing that you talk of. and for mobile phones, mine spends most of its time switched off with the battery flat in the top drawer of the bed side table, and it certainly does not take pictures.
I am glad though that there was nobody to see, as if there was, it would be a prime candidate for Jerremy Beadle's You've been framed.
Is that still going?
You tend to loose touch when you don't have a telly.
Still, it did make for a nice change. The tedium and drudgery of my monotonous work life was somehow brocken as a result.
Better to laugh than cry.
kitten75
« Reply #7 on: November 16, 2010, 01:35:16 PM »
Hi Neil
Glad someone else is struggling with their Fiat in the ice (not glad you're struggling specially but you know what i mean!) I had to de-ice mine this morning for the first time...am seriously thinking about not taking him out in the winter.
I am having problems starting too, after 4th or 5th attempt it starts but sometimes when I turn the ignition there is just a clicking sound as if nothing is happening but as I say eventually he starts. Am worried that in a while he will just refuse to start...
Mhairi
« Reply #8 on: November 16, 2010, 04:15:01 PM »
Hi Mhairi, if when you turn the key you just get a click it means that the ignition power is getting to the starter motor but the solenoid is not kicking in. Might be worth getting battery connections and all earth points checked out. If you still have the problem then you may need a new starter or solenoid. The 126fan guys are doing a new solenoid for 23 euros. On their site it is in the Electricity section , page 9 & described as "Starter Electromagnetic Coil" T65 27. If you go that way I would also go for a pair of new brushes described as "Starter Carbon" at 1.2 euros each  [-/
kitten75
« Reply #9 on: November 16, 2010, 04:29:59 PM »
Thanks Rusty...great advice.  It's going back to the garage on Monday so they can check the new engine over so will ask them to have a look...will note down what you say and ask them for their advice!
m
neil 126
« Reply #10 on: November 24, 2010, 07:17:14 PM »
O.K. I've done my best and it still isn't working.
I have replaced the solenoid and it's no better.
Bloody electrics >:(
Just to fill you in, the starter turns nice and hard but the solenid is not activating.
Any and all help appreciated.
« Reply #11 on: November 24, 2010, 07:31:03 PM »
Have you checked that there is 12v on the small wire that connects to the solenoid when you turn the ignition to the start position ???
kumar
« Reply #12 on: November 25, 2010, 11:43:17 AM »
my car wont turn over, but i can bump start it. if when the engine is running i pull the starter lever the starter will engage, then i will be able to start the engine directly after turning it off, is this likley to be anything to do with the starter solenoid?
Jeremy
« Reply #13 on: November 25, 2010, 11:49:34 AM »
Pull the lever?
Dude thats not a solenoid.
Get a piece of wood and push on the lever by hand, you may find you cable is not pulling the lever enough
kumar
« Reply #14 on: November 25, 2010, 01:55:54 PM »
yeah I'd already figured that out (the cable broke the day after i bought the car). this is something else.
