Author Topic: Aircooled heater  (Read 3440 times)
Aircooled heater
« on: September 01, 2010, 07:03:28 PM »
With winter on our doorstep, I've been thinking... and as seen in the Fiat 500 manual kindly put-up for us, there is a heater booster.
Now I find the heater to be a bit of a pest because whatever fumes lurk in the engine bay seem to end-up in the car, but the heater booster gave me an idea, perhaps with the use of an electric fan one could pull heat off the exhaust as the heater booster does. A fan isn't a silly idea anyhow as, as soon as the thermostat opens one looses alot of the hot air.
I was thinking to only pull heat off the exhausts...sounds simple but alot of work..
Re: Aircooled heater
« Reply #1 on: September 01, 2010, 07:37:39 PM »
Yes I have got my thermostat housing in for powder coating at the moment so no heater , no real problem but quite handy for the demist if I go out very early in the morning. I have been quite impressed how cosy the the car gets with the normal system even on the coldest of winter days also bearing in mind that the roof is a single layer of fabric. The early 500 heater booster consisted of a crude shroud that came out of the thermostat housing , encased the rear exhaust downpipe then fed on into the car. Only ever seen one in pictures. The later 126 cars have a heater blower to "drag" more heat from the engine  [-/
ypsilon_lancar
« Reply #2 on: September 04, 2010, 01:08:00 AM »
I remember as a kid when my parents had a Beetle most owners used to have a parafin heater on the back seat! Might not be the safest of ideas looking back but keeps the car toasty warm!!
gsxr126
« Reply #3 on: September 07, 2010, 12:54:41 AM »
I'm in the process of installing a 12v electric heater in the luggage compartment, due to removing the std running gear. They're available from any electronics hobby shop like Jaycar, cheap and very effective. NO ENGINE BAY FUMES
Its a good method for cleaning up an engine bay in a water cooled car - doing away with heater hoses, boxes, etc.
« Reply #4 on: September 07, 2010, 09:02:29 AM »
i recall darrell telling me that he had an electric heater that ran his battery flat? my solution is to open the windows before i set off on a long winter drive and when i have lost the feeling in my hands to close the widows for that psychological heat effect i also have a variety of hats that range in thickness that i keep in my car...
smallcox
« Reply #5 on: September 07, 2010, 02:59:33 PM »
Hi.
Yes Bis13 i like the hat idear but i only own a straw one. Now gentalmen we live in a modern world and the answer is simple, just buy another car for winter :D That way you can miss the salted roads and potholes that reck our little toys.(i'm talking rubbish again)
I did have trouble to in winter but as a last resort ( and my wife feels the cold and moans)I  insulated the ducting that runs under the car above the axle and the tunnel inside the car along the floor and it made a noticable differance [-/
Smallcox
edsaysyes
« Reply #6 on: September 07, 2010, 07:47:36 PM »
I know it ups the fuel consumption but did you try a gallon of petrol under the wife and light it before you go out. Will keep her warm
smallcox
« Reply #7 on: September 08, 2010, 04:27:58 PM »
i've even tryed a RED hot poker :oops: :oops: :oops:
edsaysyes
« Reply #8 on: September 08, 2010, 05:44:25 PM »
ummmm kinky
« Reply #9 on: September 09, 2010, 07:57:24 AM »
The answer is simple :D  Aircooled for summer + bis watercooled for winter [-/
« Reply #10 on: September 09, 2010, 09:16:19 PM »
You could try to fit a heater like the ZAZ 968 had, one that burned the petrol from the tank which went through a tap  ;D
st57_it
« Reply #11 on: November 18, 2010, 08:54:06 AM »
Why not mount a Webasto cabin heater?
« Reply #12 on: November 18, 2010, 09:24:21 AM »
Just to set the record strait, my heater is now the best thing since...
Thermostat seems to be behaving and all leaks etc that were sending fumes into the car have been cured.
I'd rather be in the air cooled as the heat is virtually instantaneous, when the engine fires-up the barrels start to warm and obviously warm air is pumped into the car  [-/
Aircoolers rock ;D
« Reply #13 on: November 18, 2010, 05:50:58 PM »
so i am the only one who has ice on the inside then?
« Reply #14 on: November 18, 2010, 06:41:27 PM »
Best to have a rag handy in these colder months. I immediately fogged up after driving off in the colder mornings and had to open the window a bit... true that the warm air does come in relatively quickly but only the sunshine helped with the defogging of the rear window :)
