Author Topic: Horrible Vibration  (Read 3371 times)
Bolly
  • A little shaky - but all mine!!
Horrible Vibration
« on: May 30, 2010, 06:30:20 PM »
Hi all,
my bis has a horrible problem it has a wicked vibration that goes through the whole car even when idleing with the clutch down and its almost deafening at 40mph!! the engine and gear box mounts have been replaced with no effect
many thanks
Heather
Bolly
1990 Fiat 126 BIS
Re: Horrible Vibration
« Reply #1 on: May 30, 2010, 09:42:38 PM »
is it present when the car is stationary?
or is it only when moving?
We should be able to rule some things out and figure out whats happening.
Michael
« Reply #2 on: May 30, 2010, 09:51:55 PM »
firstly have you had this car long and has it only just started to do this?
« Reply #3 on: May 31, 2010, 12:04:36 AM »
As Michael said, try and pin point where the noise is coming from, A few things to look at, check the alternator bracket for cracks, make sure the bolts are tight, Make sure the exhaust brackets and all the bolts are tight. Also check that the 4 nuts that hold the rear panel are tight, When some people change the engine they don't put the LHS (looking from the back) nuts back on because they are awkward to get to, being sandwiched between the radiator and the back panel, check the row of bolts on the top of the rear panel.
Bolly
« Reply #4 on: May 31, 2010, 08:46:42 AM »
Hello all,
the car has done 7400 miles, but had an engine fault from new ( think it was the bottom end bearings not running true)
and has spend most of its time languishing in the garage of an old boy, the body is immaculate and totally rust free underneath it also has the patina of a 2 year old car.
The previous owner to us had replaced the bottom end bearings but they soon got ruined so replaced the engine (whole unit) with a running item of unknown mileage also at the same time he replaced the clutch and all engine/gearbox mountings as a matter of course.
It now has this horrible vibration, I think it can be isolated to the engine as it does it while stationary and idling in neutral or stationary with the clutch in! and of course it does it while driving in all gears
I drove this car from portsmouth to oxford and got out nearly deaf and with tingling fingers! the whole car shakes and wobbles and you are unable to see anything out of the mirrors.........a good cellulite buster!
It does also have a small occasional misfire which we are not worried about at the moment
I took my husband who is the veteran of many car and bike restorations for a test drive he could not belive that I drove this car......but i love it, even though he wrinkles his face up at the engine and views it with much suspicion!!
He recommends replacing the engine with another good unit....we still have the 7500 mile unit for parts so I am hoping it can be fixed without replacing.
many thanks
Heather
Bolly
1990 Fiat 126 BIS
« Reply #5 on: May 31, 2010, 09:15:37 AM »
Hi Heather , from what you say here & on the other thread I would say that you have got yourself a nice little motor there (vibration apart)
I bought my wife a brand new G reg Bis when they came out & that broke a camshaft after 300 miles so nothing surprises me. Apart from the Bis head gasket I would say in general that major engine problems are rarer than transmission. From what you say I would think that you problem is a bit more serious than a loose component. I bought a spare air cooled engine recently and the rear main bearing was so worn that the white metal had melted away and the crank was wearing its way through the steel liner. Must have been hell to drive. Sure you will get it sorted one way or another  [-/
« Reply #6 on: May 31, 2010, 01:57:14 PM »
it sounds like something is out of balance would the flywheel do this? pete what did your car behave like when you had your flywheel in the wrong position?
Bolly
« Reply #7 on: May 31, 2010, 04:51:23 PM »
The flywheel might be on the wrong way if they can be fitted the wrong way as the previous owner might have kept the low mileage one for the replacement engine, I will give them a call!!
cheers
Heather
My other half is talking about rebuilding the existing engine with all new internals and getting it all balanced can you get all new replacement parts for bis? we can only find aircooled parts a NOS entire engine would be good!
Bolly
1990 Fiat 126 BIS
« Reply #8 on: May 31, 2010, 11:02:40 PM »
to be honest a second hand engine from a used bis should have plenty of good points the biggest problem area is obviously the cylinder head due to the overheating problems that exist, as for any engine refurb replace the seals bearings, rings etc you say that your husband is good with the spanners then it should be pretty straight forward i wouldnt bother with a new engine as theat would cost loads and i would think overhauling the engine you already have to be much more viable. the first thing i would do is sort the problem that you have now and move forward from there.
« Reply #9 on: May 31, 2010, 11:31:19 PM »
Yes its a good possibility the bis flywheel weighted on one side and has to be positioned in the correct place.
smallcox
« Reply #10 on: June 01, 2010, 01:08:01 AM »
Hi Bolly,
Two engines with the same problem, I agree with the guys above flywheel in wrong position. This would knock main bearings out very quickly as you described.
Sound like a good find, rust free Fiat [-/
Bolly
« Reply #11 on: June 01, 2010, 05:34:45 PM »
Hi all thanks for the reply's,
We will pull this engine out and look at rebuilding it.
many thanks
Heather
Bolly
1990 Fiat 126 BIS
« Reply #12 on: June 01, 2010, 05:58:53 PM »
Where abouts do you guys live?
Bolly
« Reply #13 on: June 01, 2010, 09:19:59 PM »
We live at Brize Norton in oxfordshire
Bolly
1990 Fiat 126 BIS
« Reply #14 on: June 01, 2010, 09:46:58 PM »
Bugger! I was hoping it was closer, I'd have popped-over and given an opinion.
