Author Topic: Cylinder Head Upgrade  (Read 6132 times)
nrg19uk
Re: Cylinder Head Upgrade
« Reply #15 on: May 13, 2010, 07:04:10 PM »
how comes yours hasent got this bit? not sure what its called
Neil gargaro
« Reply #16 on: May 13, 2010, 10:02:31 PM »
nrg it's been skimmed to increase the compression ration :P more power! [-/
Hey Rusty I'll make you an offer on that head :oops:
It's plain and simply 126 porn!
« Reply #17 on: May 13, 2010, 10:47:49 PM »
 Darrell here is a bit more 126 porn for you :). No bigger valves, but the head is skimmed to the max, and the guys were running it with no head gasket...?
« Reply #18 on: May 14, 2010, 07:10:19 AM »
The guy who does the work normally shuns publicity but he has made a guest appearance in the next two pics  :oops:
So the work goes on & he has told me that the unleaded exhaust seats that were fitted by a long established firm in Watford were well out & would never have sealed so he has sorted that out.
On this occasion  you are wrong Darrell. The clue was at the start of this thread. This is an old 499 ccs cylinder head that did not have that groove , just a small hole at each end. Although the head had been kicking around in my shed for over 30 years after a quick clean it all looked OK. I thought I would go with this head in the first instance as it probably had the most potential for improvement. I am not having it skimmed at this stage as the emphasis is on getting it breathing nicely  [-/
gsxr126
« Reply #19 on: May 14, 2010, 08:34:14 AM »
Lookin good Rusty,
It looks like the combustion chamber has been unshrouded as well as being polished (correct me if i"m wrong). If this is the case then your chamber cc's will be bigger than before which will drop the comp ratio. You may need to get the combustion chamber cc'd and see what the difference to standard is, and then evaluate the difference to see if it will work in your application. If your using a 500cc bottom end the comp will drop from standard. If using a 650cc bottom end, you may want to work out what the static comp ratio before assembly.
Dan
« Reply #20 on: May 14, 2010, 08:54:15 AM »
I'd skim it while it's off  :oops:
« Reply #21 on: May 14, 2010, 08:55:27 AM »
1973...I'm on the look-out for another head to work, that is seriously high compression  [-/
gsxr126
« Reply #22 on: May 14, 2010, 10:08:04 AM »
I'd only skim it to get it true. The more metal you have in your aircooled head the less likely you are to overheat.
That (1973) head does indeed have a very small combustion chamber and by the looks a very good design, but the compression all depends on what kind of piston is squeezing it.
« Reply #23 on: May 14, 2010, 10:17:21 AM »
I wonder if the ally rocker cover helps to keep the head cooler?
« Reply #24 on: May 14, 2010, 01:02:44 PM »
Re engine temperature , mine and the other 795 ccs Alquati engines both had oil temperature sensors fitted in the sump so it seems to be a sensitive issue.
Re compression ratio , I will find out more when I speak to the guy next but one interesting thing I had not realised was that the outer limits of the combustion chamber overhang the cylinder bores on the 499 ccs engine so a little local work at the cylinder top has been suggested. Also my thinking with this project is that as the bolt pattern on the head mounts are the same I can fit this head to a 594 , 652 or the 795 ccs engines . The "gasket blow groove" has to be filled in on the big bore engines as it is too close to the bore itself. So that problem already taken care of on the 499 ccs head. As for skimming I already have the "stage 1" head from the Alquati engine which has been skimmed & ported but still has standard valves so this could be the next one for some further TREATMENT  [-/
smallcox
« Reply #25 on: May 28, 2010, 07:54:40 AM »
Hello rusty,
I recon your going to need an oil cooler for that 795cc monster you building, hows it all going.
I like it, Steve
« Last Edit: May 28, 2010, 08:05:55 AM by smallcox »
« Reply #26 on: June 07, 2010, 05:27:39 PM »
Managed to go and collect the head today , looks promising  ::)
Not had a chance to take pics yet as I know some of you guys will nag me on this  ;D
I went armed with four other heads plus other parts to decide on the next project . One hour and 50 minutes later after mind boggling tuning talk I left the guy with 2 further projects. Apart from the newly worked head I returned home with a standard 652 ccs used head and a brand new 499 ccs head I have. I left him with the Alquati 795 ccs head , manifold & 30 DIC Weber carb to check out the work that had been done back in 1984 and make any improvements he saw fit. Then I took the "white elephant" German Bambino head just out of interest and explained the problems of using it. After much measuring etc we worked out that it could be modified back to one that could be fitted to standard 652 ccs spec in terms of tinware , push rod tubes, etc. So hope to fit the "new" head this week with other minor tweeks then other interesting stuff in the pipeline  [-/
Allan
« Reply #27 on: June 10, 2010, 12:06:54 AM »
Hi Guys,
My experience with cylinder head modification tell me that it is in fact a science and that sometimes more is often less. For example while big valves will give you a greater volume if they are shrouded by the edge of the combustion chamber then you have wasted time and money having it done. I have found that smoothing out the valve and seat radius' is a cheap and simple way of extracting small but worth while gains. Remember that one extra horsepower on a 20 hp motor is a 5% gain. I agree with the three angle valve idea. 30 45 and 70 degrees. Clean them up and get them cut so that the 45 angle matches the seat when blued. Then clamp them into a lathe or drillpress or even an electric drill clamped in a vice then using wet and dry sanding paper smooth and round of the valve. If the valve is in good condition or new start with about 320 grit and CAREFULLY work up to 2000 grit. It ain't hard work and you've only got 4 valves to do so take your time. Be a little careful in the neck area as you don't want to remove and valve material from there for fear of dropping the head of the valve. you can do the same with the seats using those little paper grinding/polishing wheels. Make sure that you recheck the seat contact with bearing blue. Lap in the valves with very fine paste. I have used Brasso to do this on some jobs but it's hard work. There are a million books out there that will tell you what you should and should not in this area and what works on one head can have an adverse effect on another.
My theory is to clean, ease where you can and polish and that will give small but inexpensive gains. If you have an old damaged head have a play with that to see what happens when you try this stuff.
Allan
