Author Topic: Engine Problem  (Read 3577 times)
Re: Engine Problem
« Reply #15 on: April 05, 2010, 05:53:58 PM »
Seems that it ain't just engines that may well be dodgey in the refurbishment department but it seems that you have to beware of so called refurbished stub axles from some suppliers. This is not a new thing as I have seen a number of reports before of recon units that fail the MOT. If you have a problem with king pins you can source a new rebuild kit under £20 & if you have a traditional motor engineer on your patch then you can get a proper job done.
